The CPC connectors will do the job nicely. The 9 conductors will allow PTC monitoring,dual charge rates, precision voltage measurements, fan control. The small PC board with + terminal connector, fuse,precision resistor, two diodes, will be very safe, so I am happy with everything about that connector, except for the $20 price tag. I will include the screw on cap for the connector for whe n it is not being used.
I had to make up some fan connector shells, order more tyco receptacles, and make more of the pins, so the fan connection will be a plug in on the insight version.
Need to get a couple of other projects off the bench before I tackle the controller/LCD display.
