Insight Central: Honda Insight Forum - View Single Post - Trunk opens over bumps a tiny bit... ???
Wheel & Tire Center
Old 12-27-2013, 02:05 PM   #3 (permalink)
3-Wheeler
3-Wheeler's Avatar
Originally Posted by ADDvanced View Post
So I noticed that my "rattle" over bumps on the highway is actually visible.....
There are rubber bumpers on the underside of the rear hatch. Mine have taken a compression set to the point that I added some thin shims to the sheet metal in the same spot that the rubber stops touch.
I used silicone adhesive to hold the shims, and now the hatch is quiet again.
Jim.
Under-Belly Smoothing Panels:
Tail Extension:
