Rebuilt transmission - Insight Central: Honda Insight Forum
Wheel & Tire Center
Old 03-16-2017, 05:46 AM   #1 (permalink)
counterbond's Avatar
Default Rebuilt transmission
Heard there was someone on here that rebuilds the manual trannys for around $300. My 2000s transmission is on its way out. Need a new one. Will send back core.
Brandon
counterbond is offline   Reply With Quote Quick reply to this message
Old 03-16-2017, 08:42 AM   #2 (permalink)
Premium Member
Balto's Avatar
Scott (KYL3CYL) rebuilds them. But not for 300. His price used to be 750 + a 250 core charge + shipping. No idea what he charges now though.
[Edit]: he replaces all the bearings and grinds the clocking tabs to get rid of the infamous 3-2 and 2-1 grind also. Just a little FYI.
Balto is offline   Reply With Quote Quick reply to this message
Old 03-16-2017, 09:30 AM   #3 (permalink)
Good morning,
If your transmission is not popping out of gear that is good. To test it you can drive and put it in each gear and then romp on the gas several times if it stays in gear then that gear should be fine, try the next gear and do the same thing. If the transmission is popping out of gear the gear set for the one or ones that are popping need to be replaced to make it reliable. Gear sets add about $300.00 to the rebuild price.
I charge $750.00 for the rebuild. This includes all new bearings and seal, friction dampers, syncro mod, weld and grind the shift fork shafts to eliminate detent ball wear. Plus shipping, I ship UPS ground. The crate with transmission is aproximately 85lbs. Also, I offer machined flywheels, exchange. New clutch kits. Rear main seals. If you want to purchase a complete bearing set with friction dampers I offer this also, all OE parts for the bearings and seals.
I have crates built to ship rebuilt units out and cores back.
Also, there is a $400.00 refundable core charge for your core and my crate.
I know there are others here on the forum who indicate they rebuild them as well, however I don't know what parts they replace. I don't think anybody else is welding up the wear on the shift fork detent area.
Scott
Silver 2000, MT 160,000mi, RE92's, S2000 leather steering wheel
Silver 2002,CVT 187,000mi
Blue 2002,MT 126,000mi, RE92's, S2000 leather steering wheel
Red 2002,MT 196,000mi, RE92's, new rear springs, GAZ shocks
Citrus 2000,MT 182,000mi, MIMA, RE92's, S2000 leather steering wheel, Japanese seat covers.
Simple grid charger SC03
New rear coil springs available, PM me.
One piece aluminum underbody panels.
PayPal:
KLR3CYL is online now   Reply With Quote Quick reply to this message
Old 03-16-2017, 09:43 AM   #4 (permalink)
Here is a photo of a transmission on the bench being reassembled. If you can zoom in on the shift fork detent areas you can see they are redone. This is now standard protocol on a rebuild from me.
PayPal:
Old 03-16-2017, 09:46 AM   #5 (permalink)
Here is a photo of of a machined flywheel and rear main seal being ready for shipping.
PayPal:
Old 03-16-2017, 09:54 AM   #6 (permalink)
Photo of a transmission being created for shipping, bolted to the crate base, machined flywheel wrapped in cardboard to the left, rear main seal taped to the transmission, information tags attached top of crate to the left side of photo getting ready to screw the top on the crate.
PayPal:
Old 03-16-2017, 12:37 PM   #7 (permalink)
Complete set of transmission bearings, seals and friction dampers.
PayPal:
Old 03-18-2017, 06:30 PM   #8 (permalink)
I took a video today of said problem. Car drives fine but sounds bad.
https://youtu.be/0sNViMmOZ9U
Old 03-18-2017, 07:21 PM   #9 (permalink)
I think your ISB is shot. let go for too much longer, and you will be popping out of gear.
Atheos is offline   Reply With Quote Quick reply to this message
Old 03-18-2017, 07:41 PM   #10 (permalink)
Idk I did an input shaft bearing on my red insight, and with the clutch out that thing was way louder than the silver one. I can hear the isb on this car at idle faintly but I don't think that's the culprit
Random Question
