Lift Cylinders for Trunk - Insight Central: Honda Insight Forum
Old 05-22-2010, 06:36 PM   #1 (permalink)
Default Lift Cylinders for Trunk
Hi there, Does anyone have a line on lift cylinders or trunk struts for holding up the trunk. Mine suddenly stopped working and the trunk is pretty heavy to hold up without them. Thanks. Bill
Cheers, Billybooch
billybooch is offline   Reply With Quote
Old 05-23-2010, 01:05 AM   #2 (permalink)
Premium Member
satchel's Avatar
$53.88 each from Majestic Honda Honda Automotive Parts
Old 01-04-2011, 05:32 PM   #3 (permalink)
Default 2000-2007 Insight Gas Charged Lift Supports
Greetings: After researching and testing supports for the rear hatch, or as some call it the liftgate, tailgate or trunk we have gone into production of the lift supports. These are high quality, made in the USA supports that are a direct fit that requires NO modifications to the vehicle. Below is a link to our site for your review, if you have any questions please feel free to send them to us.
2000-2006 Insight Hatch Supports
Thank You
Lou Fishman
Lift Supports Depot.Com
1295 Linda Vista Dr.
San Marcos CA 92078
1-760-744-2956
lou4351 is offline   Reply With Quote
Old 01-04-2011, 08:30 PM   #4 (permalink)
Premium Member
satchel's Avatar
FYI Lou, there is no such thing as a 2007 Insight.
Old 01-04-2011, 08:38 PM   #5 (permalink)
Default 2000-2006 Insight Gas Charged Lift Supports
Greetings: Thank you for the information, will revise our listings
Lou Fishman
Old 01-04-2011, 09:55 PM   #6 (permalink)
I'll be ordering a set and will post the results.
The stock struts failed on me about a week back when we hit a -10f cold snap and slowly lost oil over a few days. I didn't think they would both fail at the same time or so quickly. Its a little cheaper than the price from Honda and I figure since the Honda struts seem to fail often enough to where I'd rather try something else, I'll bite. I can't wait to put these on.
Old 01-04-2011, 10:16 PM   #7 (permalink)
lou 4351,
Thanks, mine gave out as soon as the cold weather hit so I need to order some. It is a real pain holding up the hatch while I put my stuff in there each day.
Old 01-04-2011, 10:28 PM   #8 (permalink)
Premium Member
satchel's Avatar
It's a whole Ulysses S Grant cheaper if you compare it to getting a pair from Majestic! I wish I'd found Lou when I replaced my Pathfinder's stuts as he has them for $16.
Old 01-04-2011, 10:35 PM   #9 (permalink)
joecvt's Avatar
The stock struts failed on me about a week back when we hit a -10f cold snap and slowly lost oil over a few days. I didn't think they would both fail at the same time or so quickly....
You may only have one that actually failed but the other is not strong enough to handle the additional load making it seem like it failed as well.
I had this happen to me awhile back but I purchased two from Majestic anyway (back when they would still ship them).
When it is very cold outside, I slowly open the hatch pausing a bit then opening more, pause then open till fully extended. This seems to be less stressful in the extreme cold weather. I also do this to the hood of my Lexus ES300. I don't know if this will really help to prevent failure but I have been doing that method over the last five years or so. I open it normally in the warmer weather though.
No other mods performed yet
2003 CVT Blue Insight
Low Speed Auto Stop (LSAS)
Not registered yet
Old 01-05-2011, 09:19 AM   #10 (permalink)
It seemed like that was the case the first day it happened because I raised it and it didn't support itself except at the full height it barely could hold itself up. Then the next day I opened it and it was completely limp and heavier than I thought the hatch would have been, but it makes sense, large chunk of metal and glass. They both failed, I know this because they both released out a bunch of oil.
