WTB: 1st gen with bad engine/IMA/battery (AZ) - Insight Central: Honda Insight Forum
Old 11-11-2012, 11:50 AM   #1 (permalink)
Default WTB: 1st gen with bad engine/IMA/battery (AZ)
Hello forum,
I've decided to try an interesting swap I've never seen done before into an Insight. It will retain it's eco-friendly nature and will probably even get better MPG than a standard car.
I am looking for a car to use as the shell for this project. Because it will look, act, and drive like an Insight, I need one that hasn't been wrecked.
Here's what I'm looking for:
- Good body (no crushed panels or major body damage), clean interior
- 5-speed manual preferred
- Any color
Bad engine/transmission are fine. Bad IMA is fine.
I'm located in Tucson, Arizona so the closer you are to me the better. Budget is flexible depending on the condition of the car.
Thanks!
2001 Honda Insight 5-speed Monte Carlo Blue
Turbo Diesel engine swap underway! www.hondatdi.com
Last edited by gtmotor; 12-03-2012 at 09:45 PM. Reason: Paint color (and condition) no longer matters
gtmotor is offline   Reply With Quote
Old 11-11-2012, 12:30 PM   #2 (permalink)
Originally Posted by gtmotor View Post
Hello forum,
- Good body, interior
- Blue, silver, or red preferred
Thanks!
What sort of swap do you have in mind? A K20 or something else? Interested to hear more about your project.
2003 Silver 5 speed - MIMA & Grid Charger Equipped
rayholan is offline   Reply With Quote
Old 11-11-2012, 01:04 PM   #3 (permalink)
Nah, the K20 has been done many times before
I will be swapping in a 1.9 TDI engine from a Volkswagen Beetle/Jetta/Golf. I expect good things from this power train. It's capable of 50 mpg in a car that weighs 1000 lbs more than an Insight with a Cd of 0.38 (Insight is 0.25). That along with the +30 horsepower increase and whopping +90 ft lbs of torque should make the Insight an entertaining ride.
I saw someone else had attempted a TDI swap before but after awhile they just stopped posting. I don't know if the project was ever completed or what came of it. He also used an engine out of a VW Polo which isn't available in the United States. I'll be using the fairly common ALH engine which is US legal and available to most people.
I plan on documenting the entire process via a blog. I already have the domain "hondatdi.com" and will be updating there as the project progresses.
Old 11-11-2012, 02:40 PM   #4 (permalink)
I applaud your ambition. I've had several VW TDI's (Passat & Golf) and enjoyed their relatively high MPG (relative to standard gas engine vehicles). Key factor, which I assume you've already considered, would be getting a super low numerical final drive ratio out of the VW tranny. The TDI as you know is a a torque monster especially as compared to the stock Insight 3 cylinder (even supplemented by the electric motor). Stock VW gearing would be way over-geared in an Insight. With a lower numerical final drive, I could see you loafing along at 1500 rpm's at 60 mph and still having buckets of torque available to blip up to 80 to pass traffic. The torque peak of the TDI is down around 1800 rpm or so, no?
Of course, if you're happy with a 50 mpg diesel AND the acceleration potential to embarrass lowered Honda civics, the stock VW TDI drive train in the bantam weight Insight would definitely deliver.
Old 11-11-2012, 08:29 PM   #5 (permalink)
Rush's Avatar
Hey GT, I sent you a PM.
Rush
www.TucsonEV.com
Tucson AZ
Old 11-16-2012, 12:15 AM   #6 (permalink)
After more research, it's apparently very easy to swap the 5th gear out of the TDI transmission. I will be doing a lower ratio (0.681) on the 5th gear but don't want to change the final drive. Embarrassing sporty cars with an Insight in 1st through 4th is going to be awesome
Rush, any word back from your friend with the unfinished Insight project?
Old 12-03-2012, 09:41 PM   #7 (permalink)
Still looking...
Faded or peeling paint is fine also. I have an interesting idea for a paint job
The donor car is here and ready to give it's engine up!
www.hondatdi.com
Old 12-03-2012, 11:39 PM   #8 (permalink)
Lean Burn = Happiness
jeff652's Avatar
Does it need a clean title? Of not I may have just what you need . .
Old 12-03-2012, 11:42 PM   #9 (permalink)
What was it salvaged for? If the body/chassis are straight and the interior is intact then I may be very interested
Old 12-04-2012, 12:22 AM   #10 (permalink)
jeff652's Avatar
You have a PM
