Originally Posted by bryankwalton
You can (as you can see in my post). You need to specify what your avatar should be in the UserCP.
-Bryan
I go to the 'usercp' and it shows a box where an avatar could go. the option of 'DO NOT USE AN AVATAR' is already selected as the default and will NOT let you UNSELECT IT.
also, there is no 'browse' tab to seach for avatars from your files. I've been on about 6-8 forums, all using the same format and this is the ONLY one that I can't add an avatar.
sorry, I'm just frustrated and
