Scangauge II Ultra $115 shipped eBay - Insight Central: Honda Insight Forum
Go Back   Insight Central: Honda Insight Forum > Insightful Deals > eBay Auctions: Honda Insight related
Old 10-15-2011, 11:41 AM   #1 (permalink)
Dakine's Avatar
Default Scangauge II Ultra $115 shipped eBay
Found this on eBay today. Those of you that have these gauges which would you recommend? The Scangauge II or the Ultragauge that goes for $25 less than the Scangauge II?
ScanGauge II Ultra Compact 3-in-1 Automotive Computer | eBay
Dakine is offline   Reply With Quote
Old 10-15-2011, 01:06 PM   #2 (permalink)
Kevin Dougherty's Avatar
I have owned Scagage, Ultra gage and I am presently using Torque for Android with a ELM 327 bluetooth/OBD scanner ($21 dollars for scanner and software).
Torque is the best, by FAR, Ultragage second and Scangage a distant third, in my opinion.
kevin
Old 10-15-2011, 01:38 PM   #3 (permalink)
Dakine's Avatar
Delete I found answer
Old 10-15-2011, 02:33 PM   #4 (permalink)
kevin
Old 10-17-2011, 04:23 PM   #5 (permalink)
Hi kevin, out of interest Is it easy to find out when the car is in Lean Burn with this Torque software?
Suntory1980 is offline   Reply With Quote
Old 10-17-2011, 04:31 PM   #6 (permalink)
I find lean burn when the O2 bank1 sensor 1 reads below ~.4 volts.
It is maintainable when the engine load is <~35%.
Decel fuel cutoff can be found directly by using the air-fuel status widget, or when the instant Liters / 100 km is below ~1.5 ( it does not go to zero for some reason)
kevin
Old 10-23-2011, 02:48 PM   #7 (permalink)
samwichse's Avatar
Does torque include realtime MPG? If so I might get a bluetooth adaptor for my wife's Fit.
