Lifetime MPG stuck in a loop - Insight Central: Honda Insight Forum
Wheel & Tire Center
Old 01-08-2017, 12:40 AM   #1 (permalink)
Has this ever happened to anyone?
I recently made a few long highway trips that got my LMPG up to 64.9. for the last few weeks it has been steadily going down (I normally get around 60 with my normal commute and street/hwy mix), and now I'm at 62.5.
Here's the problem: it went down to 62.2, then when I was going up a 6% grade and it went back UP to 62.5...That's impossible, cuz I was getting 25mpg up the grade (according to the real time slider thingie). So then I was going for a few more miles and it went to 62.0, so I thought it was just some weird calculation, but now it seemed normal, but then it went back up to 62.2 under heavy load.
So now it keeps going 62.2 -> 62.5-> 60.0. ->62.2->62.5->62.0->62.2->62.5->62.0. Etc, etc.
Should I just reset it? What's the deal?
SmartGoKart is offline   Reply With Quote Quick reply to this message
Old 01-08-2017, 01:24 AM   #2 (permalink)
Lyger's Avatar
do a 12v battery reset, i had something strange happen when my DC converter fuse blew under the dash(lmpg wouldn't show or update at all), resetting the battery after fixing the problem fixed it.
2000 silver 5 speed 275k (RIP, accident casualty)
2001 blue 5 speed 300k (daily driver)
Lyger is online now   Reply With Quote Quick reply to this message
Old 01-08-2017, 03:15 AM   #3 (permalink)
Willie Williford's Avatar
What miles are you showing? During the readings.
Use: 390,000 mi. @ 58.2 LMPG.
Old 01-08-2017, 02:58 PM   #4 (permalink)
What do you mean? The funky thing is that when I've got it under heavy load, say 3rd gear going up hill, it will go up to 62.5, then it'll go to 62.0 when I've been driving in lean burn for awhile.
I think it's also worth noting that FCd and all other tripdometers are working normally. It's only my lmpg with the odometer read out that it's affecting.
Old 01-09-2017, 01:57 PM   #5 (permalink)
I had the same thing happen to me yesterday on the way to Scott's in Covina.
I don't monitor the trip mpg much, so this was seen on my LMPG setting.(189K+)
It kept jumping from 58.2 back to 58.0 numerous times. It only settled back to 58.2 after I was on the way home and my avg. mpg on the trip back was much better.
I would say it is normal for the programming in the ECU to that as the miles get more and more.
Don't forget due to the weather and "winter blend" of fuel your MPG will drop a bunch.
Old 01-10-2017, 02:00 AM   #6 (permalink)
Alright, so I disconnected the 12v and it worked. Kind of strange tho, cuz when I disconnected it it was on 62.5, and when I turned it back on it went straight to 61.8, so the ECU seems like it was still keeping track..Must have been a guage cluster issue.
Now for another interesting thing: the reason I didn't reset the 12v right away (just did it today) was cuz it didn't seem urgent. So, I'm driving around today and I was like 4 notches down from a full IMA charge and all the sudden it just started dropping..All the way down to 3 notches away from complete discharge in about half a mile. No IMA light or anything..Just started to discharge for no reason. Wtf?
So, I reset the ECU and it's at full charge again and working just fine. Is there a known issue with the guage clusters where they just start acting funny?
Old 01-10-2017, 02:22 AM   #7 (permalink)
Rainsux's Avatar
This is a negative recal. The car loses track of the battery capacity and recalculates it. It would have been ok without your reset, but you forced it to do it again. Not a problem because it seems to have fixed your other problem at the same time.
An occasional recal is not a big problem, but when it starts doing it frequently there is a 1447 or 1449 coming soon. Time to grid charge.
Sam
2000 Citrus
Custom Turbocharger System
MIMA #150
BumbleBee Battery
OBDIIC&C Gauge
NM license plate KERS
Alpine Stereo
Scott's rear springs
GAZ rear shocks
Old 01-10-2017, 03:27 AM   #8 (permalink)
Previous owner actually already has it wired up for a grid charger, but he had multiple insights so he didn't give me a grid charger. I gotta get one.
Old 01-10-2017, 11:21 AM   #9 (permalink)
Rainsux's Avatar
You're half way there, then. It's cheap and easy to build one, and doesn't require much in the way of tools and skills.
Sam
2000 Citrus
MIMA #150
BumbleBee Battery
OBDIIC&C Gauge
Alpine Stereo
GAZ rear shocks
Old 01-10-2017, 08:48 PM   #10 (permalink)
Lyger's Avatar
it also takes some time for the BCM to learn just how much capacity your battery has and adjust accordingly. the level it shows after an initial reset is just a guesstimate by the computer based on the initial and after charge voltage levels.
the SOC bars may be slightly erratic for a few drive cycles til it figures things out.
Random Question
