"The Drive" article on G1: - Insight Central: Honda Insight Forum
Wheel & Tire Center
Old 04-17-2017, 11:48 PM   #1 (permalink)
Default "The Drive" article on G1:
First Gen Honda Insight, Pros and Cons - The Drive
First Gen Honda Insight, The Fine Print
The Drive - 7h*ago
Earlier this April, Matt Farah did a One Take video with a viewer's Honda Insight, and now there has been a splash of people asking about the car. In 2000*...
Sent from my iPhone using Tapatalk
Jcwhite57 is offline   Reply With Quote Quick reply to this message
Old 04-18-2017, 09:55 AM   #2 (permalink)
What a terrible article.
Daily: 2000 Insight 5spd, 205k, grid charger, 13" VX wheels, iridium plugs
Roadtrip/Towing: 1995 Audi S6 Avant
Fun: 1977 Porsche 911S Targa
ADDvanced is offline   Reply With Quote Quick reply to this message
Old 04-18-2017, 10:13 AM   #3 (permalink)
Rainsux's Avatar
+1. Whoever wrote this REALLY needs to check their facts. Previous Owner stated lots of possible problems as wide-spread facts, which they are not.
Sam
2000 Citrus
Custom Turbocharger System
MIMA #150
BumbleBee Battery
OBDIIC&C Gauge
NM license plate KERS
Alpine Stereo
GAZ rear shocks
Old 04-18-2017, 10:19 AM   #4 (permalink)
That and the article is literally comprised of potential issues. That's it. Literally no other info.
Old 04-18-2017, 10:40 AM   #5 (permalink)
Rainsux's Avatar
Exactly. Lots of possible routine maintenance problems that some see on neglected cars. NONE of the special endearing qualities of our cars were mentioned.
Sam
2000 Citrus
MIMA #150
BumbleBee Battery
OBDIIC&C Gauge
Alpine Stereo
GAZ rear shocks
Old 04-18-2017, 01:53 PM   #6 (permalink)
Premium Member
samwichse's Avatar
Not only that, but unreasonably short times for failures.
"ate the primary cats every 100k miles."
"EGR plate and EGR valve requiring frequent maintenance 20-30k miles."
"O2 sensor which is much more expensive and usually fails at 60k miles."
"all replacement packs are refurbs or rebalanced for long-term ownership"
"CVTs are known for failures around 100k depending on driving habits."
"starter which only activates in extreme cold and needs to be monitored or no start conditions occur."
What the fresh, hot, bullshit is this?
Old 04-18-2017, 02:14 PM   #7 (permalink)
Bazzetta's Avatar
What a load Of bull plop.
But the photos were nice.
2000 Citrus 5-speed MT, AC, 173k miles when purchased
2006 Red 5-speed MT, AC, 37k miles when purchased
Sold the fellow IC member:, 2004 Silver, AC, CVT, Rear Speakers
38k miles when purchased
Bazzetta is offline   Reply With Quote Quick reply to this message
Old 04-18-2017, 03:56 PM   #8 (permalink)
Well, this is the Insight enthusiasts site, so don't shoot me for saying this, but as a recent enthusiast, if I remove this enthusiasm and look through the lens of a "normal" car owner, all the points are spot on. A normal car owner is fearful of *any* car maintenance issues as every trip to the mechanic is financially painful. Relatively oddball problems cause even more fear and anxiety for such an owner. Several months ago, I was such a vehicle owner and I can say from an unbiased outsider's point of view that all the points raised are legit real world concerns for normal people. I'll highlight a few key points I have direct experience with from my short ownership of this vehicle:
-A normal person wouldn't extend O2 sensor for failing CAT and P0420. They'd be looking down at the instant salvage status of a CAT replacement
-The primary O2 sensor is indeed very expensive compared to most other cars, and affects lean burn performance directly
-The car does run out of power over extended hills, and having to downshift suddenly from 4th gear to 2nd gear up a hill is not something a normal person can be expected to deal with
-Grid charging periodically is not something a normal person wants to deal with
-I have tested probably 10 vehicles while shopping. I got lucky and purchased one without 2nd gear grind. Every other one has the 2nd gear grind due to lackluster transmission design by Honda.
Now that I'm a newbie enthusiast, I really love this car and tinkering with it. But for someone who just wants a car to go from point A to B reliably, I'd warn them against the Insight, and encourage them to go the route of a normal Civic or Prius instead, depending on if they prioritize fun driving experience or just solid reliable utilitarian transport.
2004 HCH1 180k, 2001 I1 208k, tooting around bay area, CA
Old 04-18-2017, 06:25 PM   #9 (permalink)
shoop's Avatar
Sam
As well as their spelling and grammar.
2004 Silver CVT
Gaz Shocks, KLR3CYL's Springs, Body Color Painted wheels, KLR3CYL's Aluminum Belly Panel, Hybrid Automotive Grid Charger/Discharger.
49,540 miles and counting... 1/9/17
57.5 LMPG
shoop is offline   Reply With Quote Quick reply to this message
Old 04-18-2017, 08:56 PM   #10 (permalink)
Yup, these cars certainly do have their issues.
That said, they are still awesome.
Atheos is offline   Reply With Quote Quick reply to this message
Random Question
