Swaybar bushings - Insight Central: Honda Insight Forum
Wheel & Tire Center
Old 05-19-2017, 12:16 PM   #1 (permalink)
Default Swaybar bushings
Has anyone spec'd a poly swaybar bushing for our cars?
It's my favorite mod since it's cheap and has a huge difference in response and handling.
Daily: 2000 Insight 5spd, 225k, grid charger, 13" VX wheels, iridium plugs
Roadtrip/Towing: 1995 Audi S6 Avant
Fun: 1977 Porsche 911S Targa
ADDvanced is offline   Reply With Quote Quick reply to this message
Old 05-19-2017, 12:20 PM   #2 (permalink)
Which bush do you mean exactly.. (Pic) We use different descriptions over here perhaps?
IIRC A lot of experiments with poly bushes have not been a huge success on these cars for some reason. The rear motor mount is a prime example and replacing the soft rubber bush causes huge vibration feed into the body..
Pcb's/Built Units for ObdIIc&c, Imac&c, ImaBoost, Current Hacks available. Enqs to 150mpg[at]gmail.com
retepsnikrep is offline   Reply With Quote Quick reply to this message
Old 05-19-2017, 01:26 PM   #3 (permalink)
Lyger's Avatar
poly sway bar bushings help reduce roll by holding the bar more firmly between the axles so they work more uniformly.
but don't look at me, i accept the mushiness of the car, as i already have a sports car that rides stiff.
2000 silver 5 speed 275k (RIP, accident casualty)
2001 blue 5 speed 300k (daily driver)
Lyger is offline   Reply With Quote Quick reply to this message
Old 05-19-2017, 08:03 PM   #4 (permalink)
eq1
eq1's Avatar
I removed the front anti-sway bar and run stiffer springs. I don't think stiffer sway bar mount bushings would make much difference in the Insight... The linkages aren't very direct, the distance between the mounting point on the strut and the bar bushing mount point/fulcrum is long/not very direct - so the amount of slop and flex, etc. along that length is likely to overwhelm any reduction in slop you'd get by installing a stiffer bushing at the inside mount point... Something like that, just some theorizing... I like the no bar/stiffer front spring ride/performance better than stock...
2000MT, CAN, ~168K miles
Old 05-22-2017, 02:00 AM   #5 (permalink)
I think you are correct sir. Our sway bars are too tiny to notice a difference from a poly bushing
Basicburton is offline   Reply With Quote Quick reply to this message
Old 05-22-2017, 03:18 PM   #6 (permalink)
So lots of opinions but no info on the original post.
I've installed poly swaybar bushings in the past, and it always makes the bar act like a larger bar. It's one of my favorite mods. Just wondering if there was an off the shelf bushing.
Old 05-22-2017, 03:28 PM   #7 (permalink)
eq1
eq1's Avatar
Originally Posted by ADDvanced View Post
Has anyone spec'd a poly swaybar bushing for our cars? It's my favorite mod since it's cheap and has a huge difference in response and handling.
No. And they wouldn't make much difference anyway.
Old 05-22-2017, 05:05 PM   #8 (permalink)
Lyger's Avatar
a lot of 'upgrades' for the G1 are owner made, but polyurethane isn't extremely difficult to work with, and with some measuring you could probably find something close that might be a direct fit.
most people start at the back end of the car, because it's got by far the worst suspension and upgrades there make big differences in the car overall.
Old 05-22-2017, 06:09 PM   #9 (permalink)
We don't have a rear swaybar.
And idk why, I have no issues with the spring rates. My car drives/handles great, does not bottom out. >shrug<
Old 05-22-2017, 07:29 PM   #10 (permalink)
Lyger's Avatar
if you watch insights race you will see how much roll originates from the back end.
here's a pic from bluesights autocrossing:
http://andyseipos.com/p264282327/h23d0b199#h23d0b199
Random Question
