105,000 Service - Insight Central: Honda Insight Forum
Old 07-16-2007, 01:14 PM   #1 (permalink)
Default 105,000 Service
Well it's time for the 105,000 service. I'm also changing the brake fluid as I don't think it was done at 90,000.
Is there anything in particular I should watch for? (Other than the bleeding of the coolant system?
Does the coolant go in full strength or do I dilute it? I didn't see that anywhere I've looked.
Thanks,
Robert
Robert Frost is "The original Bad Bob, not Dirty Bad Bob from New Mexico."
From the "Life and Times of the Judge Roy Bean"
2000 Citrus #2757 206,000mi.
originalbadbob is offline   Reply With Quote
Old 07-16-2007, 04:47 PM   #2 (permalink)
Kevin Dougherty's Avatar
The specified Honda coolant is not diluted.
kevin
Old 07-16-2007, 07:14 PM   #3 (permalink)
Default Coolant
This may be a confusing answer Kevin. I hope my reply helps.
The Honda coolant supplied in the UK is the correct strength as supplied, and is added neat to the system, it is a 50/50 blend of water and the proprietory ingredients. So it needs no further dilution. I imagine it's the same in the US but you never know.
Old 07-17-2007, 09:58 AM   #4 (permalink)
Thanks guys for reading the post and giving me the answer. I checked with the dealer and they said it was pre-mixed.
It is, however, a different color... blue instead of green. The parts guy said that animals are less likely to drink the blue. I thought they saw in black and white??
Old 07-17-2007, 11:36 AM   #5 (permalink)
I don't think the color really matters to animals as much as the smell and taste does. If it is not enviormentally safe anti-freeze, keep it away from all animals and dispose of it properly.
Scott
02 Insight CVT
51.7 LMPG
Scott is offline   Reply With Quote
Old 07-18-2007, 09:29 AM   #6 (permalink)
In my experience, all of the coolants taste equally good. The "low tox" stuff is just less likely to kill you when you drink it.
Make sure to follow the coolant bleeding instructions in the service manual to the letter. This is very important to keep air pockets from developing in the head.
48V Custom Aluminum Scooter
Old 07-23-2007, 11:18 AM   #7 (permalink)
I did the service yesterday, and it was pretty much as the book describes. I was surprised how long it took idling to get the radiator fan to come on twice.
The best thing I bought was a Sta Lube fluid pump. Less than $10 at the auto parts store. It will screw on a wide mouth quart bottle or a gallon jug and has a sqeezable ridged end on the transfer tube that grabs the threads in the fill opening to hold it in place. I used an empty mobil 1 oil bottle and put the transmission fluid in it. 20 pumps later it was empty.
It saved a bunch of time, and was not too messy.
robert
