Squeeking noise when warmed up (at idle only!) - Insight Central: Honda Insight Forum
Old 04-10-2008, 07:28 PM   #1 (permalink)
Default Squeeking noise when warmed up (at idle only!)
I have a 2000 5-speed with high miles. The car runs great but when it warms up, it develops this squeeking noise at idle only. If I rev it even 200 rpm more, it goes away. It is fine all the time over 1200 rpm. It is in the engine compartment, and at first I thought it might be the serp. belt. But it is not. I can push in the clutch, but the noise does not go away, so I don't thing it is the throw-out bearing. I can't pin point it, but It does sound like it is coming from the rear of the engine though. Any thoughts from anyone with a higher mile (over 150k) car that may have had the same problem? Thanks!
Old 04-11-2008, 01:30 AM   #2 (permalink)
Default Re: Squeeking noise when warmed up (at idle only!)
First "CAT" heat shield.
Old 04-11-2008, 07:38 AM   #3 (permalink)
I'll check it out, thanks!
Old 04-16-2008, 10:35 AM   #4 (permalink)
not a belt pully or water pump?
2000 Insight #1346, 56K miles
LMPG = 72.1 and rising!
running Mobil 1 0W-20
personal best-970 miles on 1 tank @ 76.1mpg
bagwell is offline   Reply With Quote
Old 06-08-2008, 04:52 PM   #5 (permalink)
what was it, ever figure it out?
2000 silver MT 122k
121k crankshaft seal
113k p1447 pack/mcm/bcm
105k engine grounds
43k LAF sensor
Old 06-08-2008, 07:36 PM   #6 (permalink)
It happened only at idle on the first day I picked it up and drove it back from MI about 330 miles. The car had been stored for the winter up to that point. Whatever it was, it went away when I put it on the road and drove it. Something not lubricated or dry maybe? Either way, I've been driving it every day now for a month or 2, and the noise has been gone. I think it just had to do with it being stored and not being driven at all for quite a while. Thanks guys!
