Better headlamps - Insight Central: Honda Insight Forum
Old 06-23-2008, 08:40 PM   #1 (permalink)
nickatnite's Avatar
Default Better headlamps
I want to replace my stock headlamps with the H4 Osram Silverstar +50% - getting them is easy, but how the heck do you pull out the old ones and install the new ones? I can see one of the rear connectors (the one on the drivers side) but unless my hands are flat as a pancake and I have eyeballs on the ends of my fingers, this must not be how you get to them. Any ideas?
Thanks,
Nick
Nick
2000 Silver 5 speed "Astro"
Scangauge II (Love it!)
nickatnite is offline   Reply With Quote
Old 06-23-2008, 09:37 PM   #2 (permalink)
Default Re: Better headlamps
there's rubber dust covers that pull off then the wiring plug will pull off....finally a metal clip holds the bulb in.
....and I would recommend Silverstar ULTRA bulbs ---- brighter, whiter light.
2000 Insight #1346, 56K miles
LMPG = 72.1 and rising!
running Mobil 1 0W-20
personal best-970 miles on 1 tank @ 76.1mpg
bagwell is offline   Reply With Quote
Old 06-23-2008, 10:17 PM   #3 (permalink)
nickatnite's Avatar
Can you get to the dust covers and the clips from the top? Are the ultras better than the +50%? On another subject - I am going to go synthetic when I do my next oil change - why did you pick the viscosity that you did?
Thanks,
Nick
Nick
Old 06-23-2008, 10:26 PM   #4 (permalink)
Thanks,
Nick
honda calls for 0w20 in the insight, and the manual states that you can run 0w30 or 5w30 as a backup.
2000 silver MT 122k
121k crankshaft seal
113k p1447 pack/mcm/bcm
105k engine grounds
43k LAF sensor
Old 06-24-2008, 04:26 PM   #5 (permalink)
be careful with the coolant overflow bottle. when i reinstalled mine after replacing the headlamps i didnt notice that the little tube inside the bottle connected to the cap had fallen off into the coolant. after a few days of driving all the coolant had been pumped out of the system! mucho hotness for my little engine! no damage though. found the problem, put the tube back on the nipple, serviced the system, and been driving it ever since.
2000 Silver MT Insight
WAI, HTR200, Kenwood MP3 head unit, 3 MTX stealth subs, very-high-mounted 4th brakelight, yellow-top, tinted, SG2, MIMA, center armrest.
HafNHaf is offline   Reply With Quote
Old 06-24-2008, 09:01 PM   #6 (permalink)
nickatnite's Avatar
Thanks - Hafnhaf - where did you get the center arm rest?
Nick
Old 06-26-2008, 09:05 AM   #7 (permalink)
i built it there are some pics on greenhybriddotcom in the share photos section.
Old 06-27-2008, 03:06 AM   #8 (permalink)
Armrest King in Canada makes a nice unit for $96.00 US shipped. Took about a week to get to SoCal after I ordered online. Very prompt service!
http://armrest-autoaccessories.com/pb/w ... 97bea.html
I've had one in my 2000 Insight for 3 weeks now and like it very much. Some think it pricey, but I believe it is a good value and well worth the money. I painted the mounting base gray to match the Ebrake console. Rather than drill holes into my console and use the included screws, I mounted mine with silicone seal. It looks factory!
Patrickmilburn is offline   Reply With Quote
