'Search' is your friend. "wet seatbelt" "windscreen replacement" etc etc
It's a clip nightmare under that piece of trim, and they all break when you remove it to do a windscreen, so yours may have been replaced but they did not order the clips to do the job properly
If it's missing the little black rubber clip seals under there, then it will leak as you have noticed. It's a common issue.
