Got the sub and terminal cup mounted. Any suggestion on what to do if one of the screw holes met with the woofer cutout and busted through? The speaker is designed with very little clearance and I didn't get it centered right - it's not an issue with your box. I'm thinking I'll epoxy putty the hole shut and try and drill the screw through again - or I could leave it and run with 7 out of 8 screws.
I hope this clears the fender, or I'm screwed =p
