Front Parking Light -> DRL? - Insight Central: Honda Insight Forum
Old 08-08-2010, 06:59 PM   #1 (permalink)
Default Front Parking Light -> DRL?
I parked my car and turned on all the possible lights and that Front Parking Light (FPL) doesn't turn on. Is it simply out of bulbs? or is not suppose to be on US models?
If it's something "junkie" part of US model, I was wondering if anyone turned that FPL to DRL. I own a delsol and it has an Aux light which only turns on if headlight is on. However, with a few wire switching, in fact only 2 wires, it turns on and off without headlight turned on, so I'm using it for DRL.
Anyone done?
delsol7 is offline   Reply With Quote
Old 08-09-2010, 09:28 AM   #2 (permalink)
Anyone done?
I've test drove a few of the insights before buying one.. The parking lights make the light you are indicating turn on. If you signal, they blink as well. Most likely the bulbs burnt out and the previous owner never replaced them.
The Citrus has returned. The Citrus has returned!
kitkit201 is online now   Reply With Quote
Old 08-09-2010, 10:01 AM   #3 (permalink)
Um... mine must have burn out then..
Old 08-17-2010, 03:52 PM   #4 (permalink)
Just an FYI on this topic.
The Canadian Insights use the high beam filiment on reduced power for a daytime running light. They come on when the parking brake is released and go out when the regular headlights are turned on.
Indeed your parking light bulbs must have burned out. I've had to replace one of mine as well.
BillR is offline   Reply With Quote
Old 08-17-2010, 04:02 PM   #5 (permalink)
I'm currently thinking of turning those two round light on headlight into DRL. When I get it done, I will post. I think it will look good.
Old 08-17-2010, 04:06 PM   #6 (permalink)
No need to bother, i have done this and the two round parkinglights are too small to be seen in daylight / to be used as DRL.
2000 Red Insight MT. #032
IMAC&C & OBDIIC&C.
faxe is offline   Reply With Quote
Old 08-17-2010, 04:23 PM   #7 (permalink)
Hum... do you have the schematics of the wiring?
What's bulb that you used?
Old 08-18-2010, 12:02 PM   #8 (permalink)
aisbell's Avatar
I agree. I've been attempting to use my parking lights as DRL's while driving through Sweden and Norway. Drivers have been flashing their headlights at me because they don't think that I have proper DRL's turned on. Low-beam headlights or fog lights would suffice, but I have not wanted to use my low-beam headlamps as DRL's.
I have considered replacing the 5W parking light bulbs with LED's as bright as I can find that require no more than 5W power. I think that faxe may have done this but without success, so I am concerned that they would not be bright enough to be seen clearly.
Instead, I am considering installing in the bumper on both sides of the lower center air intake a string of bright LED's like Audi and Mercedes use. Is there room behind the bumper to install any sort of lights in this location? I realize that I would need to cut holes in the plastic bumper cover.
Aloha,
Art Isbell
2000 Insight A/C #559
Old 08-18-2010, 01:33 PM   #9 (permalink)
I did not wire the lights separately, as Art writes, i put in some new
bright LED bulbs in my parkinglights, and tried driving with only the
parkingligts on, and in bright daylight they are barely visible at all.
The small round parkinglights are simply too small.
Art: If you do not want to cut holes in your front bunper, you could
try the selfadhesive strings of LED's.
Thomas / TRI are currently digging into this.
IMAC&C & OBDIIC&C.
Old 08-18-2010, 07:57 PM   #10 (permalink)
Anyone think this is possible?
When we turn on the parking light, it turns on the signal light and tail light.
What if there is a way to turn on only signal light and not to turn on the tail light and make the tail light to be turned on when night driving light is on.
We rarely turn on only the parking light and drive right?
What do you guys think? Usually turn signal light is much brighter than those two small round lights.
