Originally Posted by porshuh
I am also curious what IATs people see in the summer with stock intake
I've had
42C, 107F with normal intake in the
Alberta Badlands, not unlike some parts of SW USA in part.
Have seen 50c, 122F with my hot air mod that loosened up and was sitting directly on the heat shield in 25C, 77F ambient temps, ... crawling in city traffic on hot asphalt. [pulled over and moved it]
No gains over 110F [43C] so is said in the old reports in the forum.
fwiw: VW aims for 86F, 30C for their vehicles' 2.0L engines for efficiency if I recall what was written on their warm air box if that matters for winter.
EDIT: I have run
my own rudimentary version of the the warm air mod in -20C conditions for a few days now and observe that at speeds below 70kph and lower, the
intake air temp has been as high as 9C, closer to 70kph it's nearer to 6C. At highway speeds of 100kph and more, the IAT in the -20C ambient conditions with considerable windchill is around 2C ±2 Celsius degrees.
I have the radiator blocked completely, however the upper and lower air entrances below the hood and at the grill are not covered as yet.
I have today adapted an aluminum roast pan by wrapping it around the catalytic converter heat shield to duct more warm air to the intake.
Radiator temperatures can be seen at 92-93C ±3 Cecilius degrees in cruising with the rad blocked after some effort getting heat into the engine. The highest temp, 95C is seen for a very brief time.
Without the rad covered, in ambient –20C, the coolant temperature was only around 67C on the highway.
The coolant temperature indicated was -2C, after sitting all night and half the day without starting, which calls into question the accuracy of the Insights coolant sensor as read by the Scangauge at lower temperatures.
None the less, plugging in the vehicle's block heater for about two hours in a sheltered location in -20 conditions, which can fairly safely be assumed to be the real temperature of the antifreeze, resulted in a measured value of 23C. Upon starting the vehicle with mixing of the fluid in the coolant system the temperature rapidly declined to 18C. The warmup period was markedly quicker, getting to above 60 degrees in approximately 4 or 5 miles in weekend light city traffic. Heater was on maximum 32C, fan was maximum defrost setting which involves the A/C.
Fuel consumption was in the order of 5L/100km, the IMA is compromised by internal resistance lessening assist and regen bars, but the SOC was reading full charge, yet force charging at 4 bars while the vehicle warmed.
Eventually with warmth the IMA was almost normal... and that's about it
[edit: later addition of
aluminum roast pan as shroud around heat shield for warmer air intake and more lean burn.] [link to pic of
ambient sensor relocation for more autostop]
