Originally Posted by Eli
It's been suggested that you could take apart a brand new EGR valve and flip the fork the other way. This should allow the EGR valve to last nearly indefinitely.. Maybe the next time it fails, I will do this.
I suggested Eli try this because I've done this and haven't had ANY issues with it.
You will need soldering equipment, a screwdriver and some wire.
// Disassembly
To take it apart, use a thin flat screwdriver and pry the tabs around the retainer ring on the top sensor portion. You have to get every tab to get the ring off. This is the hardest part of disassembly.
Once you get the ring off, the top section will lift more on one side than the other (it will be pretty hard to lift). Pry it off from the side that lifts more. Something inside will pop or break (this is normal). It's very important to cut the posts or wires when the cap comes off (if they're still attached).
After the top is removed, you'll see on the bottom of it, there's a center section that can be pried out. Be VERY gentle prying it out, and get at it from multiple angles. It should slide straight out. DO NOT pull it out at an angle.
*SMALL PART WARNING*
The center section should have a moving plunger where you'll see the metal 'forks' retained by a press ring. Remove the press ring and fork (wiper) unit. Bend the forks the other way. Basically if you were to flip the forks over, the fingers would not be pointed into the plate they ride on.
// Reassembly
Tighten the press ring with pliers before you secure the fork on the plunger (it loosened when you removed it). Reassemble the plunger section into the main top housing.
Depending on how your sensor portion broke from the mechanical section, you need to solder wires to the coil wires on the mechanical section, and solder the other ends of the wires to the sensor section, where the posts are or where they broke from. Use silicone around the solder joints to keep them from moving during use
Put the cap back onto the mechanical section and snap the retainer ring over it.
Congratulations you have an EGR valve that won't wear out (in theory)!
