Anyone ever sleep in their insight? Tips? - Insight Central: Honda Insight Forum
Old 10-17-2011, 07:42 PM   #1 (permalink)
Default Anyone ever sleep in their insight? Tips?
I have done this in my other cars in the front seat. Has anyone done it in their Insight? How was it? Any tips?
insightbuyer is offline   Reply With Quote
Old 10-17-2011, 07:53 PM   #2 (permalink)
I've done it quite a few times. It's not exactly the most comfortable car to do it in, but it's manageable.
For me, having ample leg room is more important than being able to recline the seat when sleeping, so I keep the seat how it is when I drive - all the way back. Then just snooze away..
Old 10-17-2011, 08:57 PM   #3 (permalink)
I slept in my 2000 Insight last year. It was after a Bruce Cockburn concert in Aspen ($$$$ hotels), April (cold).
I put the seats all the way forward, tilted one forward, placed a memory foam extending all the way from the back to the front between the seats. Slid into my sleeping bag, my head right below the back window. Comfy? no, but it worked. Helps if you're short, also.
leedvm is offline   Reply With Quote
Old 10-17-2011, 10:04 PM   #4 (permalink)
The passenger seat is better than the drivers for naps. The pedals are in the way.
Old 10-18-2011, 10:31 AM   #5 (permalink)
This sounds like the best option if you actually need a full nights sleep. I've always just snoozed for a couple of hours and continued on my way.
Old 10-18-2011, 02:38 PM   #6 (permalink)
I would think a cool panel could be made that would stretch from the hatch, all the way up to the dash board. Apply sleeping bag, rinse, and repeat...
porshuh is offline   Reply With Quote
Old 10-18-2011, 03:49 PM   #7 (permalink)
I don't understand how you could have done this. I am assuming you laid head near hatch, feet near radio.
First you have that lip that seperates the trunk from the front area, then you have all that area between the seats and the shifter. How were you able to lay across the car?
Old 10-18-2011, 03:53 PM   #8 (permalink)
If your head is all the way back to the rear hatch, your feet won't extend all the way to the radio. Might actually be pretty comfortable, if you push the seats forward and let your legs dangle over the edge behind the seats. Use a blanket or something to mask the big lip in the hatch area.
I've never tried it, but I can understand how it could work as long as you're not too tall.
Old 10-18-2011, 06:49 PM   #9 (permalink)
Don't try to sit up though...............CLUNK.
Old 10-19-2011, 01:39 AM   #10 (permalink)
madmanmostafa's Avatar
Send a message via MSN to madmanmostafa
I've actually slept in my car in that position. I parked my car under a tree, laid back there on the hatch, and took a nap. And yeah, hitting your head is inevitable. Looking up and seeing sky, it's only natural to sit up completely.
One thing that's also comfy is laying across both seats. Putting the car in gear and taking off the E-Brake then sitting on the passenger side and laying your feet across to the driver's side. It's not Super wide so if you're any normal height, you'll be sitting up mostly, but it's comfy if you have the windows down and you lay your head on the edge of the door. It's only scary looking up because you realize your face is exposed to the guano that the local birds fling through the air.
madmanmostafa is offline   Reply With Quote
