Poor highway mileage - Page 3 - Insight Central: Honda Insight Forum
Old 11-04-2011, 10:03 AM   #21 (permalink)
It sounds to me like you're still using too much assist. 5th gear is not for climbing steep hills.
It's better to downshift and use engine power than to run your battery dead climbing a hilll, only to spend the next 30 minutes charging it up. That will destroy your overall MPG. Unless we're talking about a mountain pass, where it's easy to recharge on the way down, this should be avoided.
The car requiring too much assist all the time could be a symptom of your tires. That's one of the things I noticed when Insight #2 had the wrong shoes on. Assist was nearly impossible not to use when trying to accelerate. Especially when starting off. It would go higher on the assist gauge and last longer, despite lifting my foot to try and avoid it. With the wrong tires, the SoC gauge lived in the bottom half with my fiancee driving it. With the correct tires, even she can maintain it in the top half.
Eli is online now   Reply With Quote
Old 11-04-2011, 11:43 AM   #22 (permalink)
Originally Posted by Balboa View Post
Higher octane didn't do anything.
You ran through a tank in two days? It took me five weeks to use it up and get back to Regular!
Yes you need to catch up with maintenance, but the key to great mileage is to slow down, stay in Lean Burn as much as possible, and stay out of the battery. And have the right tires.
Oh. And only go downhill and always have a tailwind.
Sam
2000 MT Silver
MIMA #150
Rainsux is offline   Reply With Quote
