If you travel fast on the highway, they should be good for a couple percent. If you normally drive pretty slow, they will likely have a negligable effect on MPG.
Probably the cheapest thing to do would be to buy a piece of aluminum or plastic and make your own. Several members here have done just that. It's also said that a single piece under engine panel is easier to remove when doing things like an oil change.
