Bridgestone-Potenza RE92 In Stock - Insight Central: Honda Insight Forum
Old 12-02-2011, 10:43 PM   #1 (permalink)
pennyduke's Avatar
Default Bridgestone-Potenza RE92 In Stock
I just checked the Costco Tire site and it shows Bridgestone-Potenza RE92
in stock. Get some...
Mike
pennyduke is offline   Reply With Quote
Old 12-02-2011, 11:10 PM   #2 (permalink)
RedJellyBean's Avatar
I went through a real headache trying to replace two bald RE92s yesterday, I was just lucky to find a Firestone dealership that was able to source the tires locally. Why are these tires so hard to find?
2002 Red Honda Insect 5MT
Old 12-02-2011, 11:28 PM   #3 (permalink)
They're not normally. This same thing happened back in 2009 or so, where they were on backorder everywhere.
Old 12-03-2011, 05:15 PM   #4 (permalink)
Default Tires
I ran into this problem a few years back - as Eli says it probably was 2009 or so. Nobody could get the tires except Tire Rack - said they had a good stock. You have to pay shipping and Schwab will charge you extra for mounting but I wanted stay with original tires. Last go around Schwab had no problem getting them.
rabbett is offline   Reply With Quote
Old 12-03-2011, 08:22 PM   #5 (permalink)
I don't see them on the site, only a set of Michelin energy savers?
jme5343 is offline   Reply With Quote
Old 12-03-2011, 09:02 PM   #6 (permalink)
I had luck this past week at a Firestone tire dealer, they had one in stock and got the last tire in San Diego ordered in for me the next day (Sorry SD area Insighters, my rears were bald and one had lost its tread, I had to!)
Old 12-04-2011, 03:01 AM   #7 (permalink)
aisbell's Avatar
I didn't see anything listed but the Michelin Energy Saver when searching by car model (i.e., our Insight). If I searched by tire size, nothing, not even the Michelin Energy Saver, was listed for 165/65R14, which makes no sense because the 165/65R14 Michelin Energy Saver was listed for our Insight. However, when I searched for 175/65R14, the RE92 (among others) was listed, but this size is very different from the 165/65R14 size (e.g., much heavier, not low rolling resistance).
Aloha,
Art Isbell
2000 Insight A/C #559
Old 12-07-2011, 05:57 PM   #8 (permalink)
Premium Member
thedhgroup's Avatar
Exclamation
One of mine developed a bubble on the tread. Still holds air but not sure for how long. I need 2 tires like now. I tried Cosco, ebay, tirerack and a few others. Nobody has one them stock. Anybody got a pair they have been holding on too that you would like to sell? Even a used pair with 10k miles left on them would work. New is good too if anybody knows of any.
Thanks
thedhgroup is online now   Reply With Quote
Old 12-07-2011, 07:13 PM   #9 (permalink)
I would check with a Firestone dealer, same company as Bridgestone.
Old 12-08-2011, 02:07 PM   #10 (permalink)
Premium Member
thedhgroup's Avatar
I checked with my local Dealership and they say there is none in their warehouse and that if any dealer had them in their back room, it would not show up on the national system. Not sure all that is true but if the dealer in San Diego has them I need 2 at least. Anybody know which store had them?
