Battery Pack Weight - Insight Central: Honda Insight Forum
Old 12-24-2011, 02:46 PM   #1 (permalink)
Talking Battery Pack Weight
Could some one tell me what the battery pack weights in my 2000 Insight?
gizzsabu is offline   Reply With Quote
Old 12-24-2011, 03:09 PM   #2 (permalink)
Vendor
67 lbs with fan
Old 12-24-2011, 04:59 PM   #3 (permalink)
Thanks, Mike I believe said it weights #80,but I like #67 better when pulling it.
Old 12-24-2011, 05:21 PM   #4 (permalink)
The BCM/MCM and their bracket probably add another few pounds, but yeah.
Old 12-24-2011, 06:50 PM   #5 (permalink)
Yeah, they add a bit. I weighed the "entire" package (pack, BCM and MCM) at 73 pounds with my bathroom scales. so the entire package is 73 pounds plus/minus your feelings about bathroom scale accuracy. I used a hydraulic arm type engine hoist and that approach works great if you have it. Gotta drive LR onto a ramp and remove RR tire for hoist clearance.
Lifting the pack out alone is a receipt for a back injury or a damaged terminal board.
Old 12-26-2011, 12:05 PM   #6 (permalink)
Vendor
That's why our instructions have a helper in the front seat lift the pack at that end while the person behind the car (or on the side of the car) lifts and pulls toward the rear of the car. Then it's a dead lift out, but it's at a good angle.
Old 12-26-2011, 12:08 PM   #7 (permalink)
Vendor
We don't ship with a BCM or MCM and our instructions have those parts removed from the battery before the battery is lifted out of the car, so I can only tell you the battery weight.
Old 12-26-2011, 12:45 PM   #8 (permalink)
No matter how much it weigh, it "almost" cost me a fresh pair of underwear
when i took my battery out the first time....
2000 Red Insight MT. #032
IMAC&C & OBDIIC&C.
faxe is offline   Reply With Quote
Old 12-26-2011, 01:05 PM   #9 (permalink)
Thats because you are useing your stomach muscle, because your arms are extended while lifting. Crawl inside the trunk area and use your arms muscles.
(Pampers are cheap).HEE HEE
Old 02-13-2012, 03:36 AM   #10 (permalink)
I guess some of us are lucky enough to have a cherry picker around to do the work for us.
2001 Insight CVT #2657
211,136 miles 10-22-11
Color: B-66P= Monte Carlo Blue Mica
2001Insight is offline   Reply With Quote
