Front inner marker/signal lamp - Insight Central: Honda Insight Forum
Old 01-01-2012, 01:50 PM   #1 (permalink)
Default Front inner marker/signal lamp
The insight I picked up is missing the bulb that goes in the drivers side headlight, behind the reflector that would shoot light to the side of the car (near the vertical adjuster). This explains why the headlight had moisture inside when I got it but I do not see the wire/bulb holder anywhere in the area. Where does the wiring come from/branch off of? I'd like to pinpoint this and get the headlight sealed again with a new bulb.
Masejoer is offline   Reply With Quote
Old 01-01-2012, 10:19 PM   #2 (permalink)
Found it - dangling low and stuck between some things. Replaced both marker lights on that side with 168 bulbs and all seems well now.
