Power outlet fuse? - Insight Central: Honda Insight Forum
Old 01-10-2012, 05:35 PM   #1 (permalink)
Default Power outlet fuse?
I think my power (lighter) outlet stopped working. Where's the fuse? I couldn't find it listed on the fuse box.
2000 MT, 201k mi. 50-60 mpg
Kumho Solus Eco 175 tires @45
Geodesiq is offline   Reply With Quote
Old 01-10-2012, 07:23 PM   #2 (permalink)
check fuse #12 under the instrument panel.
2000 Honda Insight 5 speed silver
2000 Insight 5 speed Citrus
2003 5 speed HCH
2005 FEH with navigation (Sold)
Calpod is offline   Reply With Quote
Old 01-11-2012, 11:13 AM   #3 (permalink)
I don't see any fuse box under either the driver or pass side dash.
EDIT: THERE it is. You really have to do some contortions to get to it.
Old 01-11-2012, 11:30 AM   #4 (permalink)
diamondlarry's Avatar
It is all the way against the side of the car up above the bottom of the dash.
Silver '00 MT
85.5 LMPG
Calpod switch
Warm air mod
Grill block
EPS fuse removed
grid charger
OBDII C&C gauge
Old 01-11-2012, 11:38 AM   #5 (permalink)
The fuse guide is on the back side of the little cubby pull out thing, aka change holder for me.
Old 01-11-2012, 12:03 PM   #6 (permalink)
It is removable. Then you can see the fuse panel easier.
Old 01-12-2012, 12:42 PM   #7 (permalink)
Do all insights have 2 power outlets (lighter) receptacles? Mine has one by the useless cup holders and one down under the steering wheel. Neither are working so I am going to check the fuse. Is there a fuse for each? Thanks.
zindude is offline   Reply With Quote
Old 01-12-2012, 12:52 PM   #8 (permalink)
The one under the steering wheel was not put there by Honda. If it's blowing fuses start looking at that one for the short.
Sam
2000 MT Silver
MIMA #150
Rainsux is offline   Reply With Quote
Old 01-12-2012, 03:04 PM   #9 (permalink)
As Sam said, the Insight only has one 12V outlet stock.
