Extreme Cold Weather Driving??? - Insight Central: Honda Insight Forum
Old 01-13-2012, 05:54 PM   #1 (permalink)
Default Extreme Cold Weather Driving???
Hello.
It is going to be about 5-10 degrees here in the morning. I have been using my truck the last couple days because of ice and snow. I plan on driving the Insight tommorrow,,,,can't stand watching the gas gauge in my truck moving to empty,,,, How does your drive in the real cold weather?
Thanks
Darrell in Indiana
madapple is offline   Reply With Quote
Old 01-13-2012, 05:57 PM   #2 (permalink)
No problems overall.
When it's that cold, it will start with the 12V starter, so make sure your 12V battery is healthy. Assist and regen will also be quite limited. Block heater is recommended, both for your health and the engine's health.
Other than that, it's really not any different. MPG will suffer.
Old 01-15-2012, 12:16 PM   #3 (permalink)
AbCaRed00's Avatar
The IMA cells will have strong internal resistance when extremely cold and will take a while to warm to become fully functional.
The SoC was 19-20bars on mine with forced charging at 4 bars after startup in the extreme cold i.e. -20C region. The 12V starter activated; coincidentally, I thought I bumped the key on ignition that day due to shivering. lol
After a brief warmup to get oil circulating etc, and soon on the road, Assist and Brake Regen were limited, gradually increasing yet held back from full function until the IMA battery cells warmed internally from light use, and externally via cabin temp air that circulates through the IMA battery case. The full range of operation came back after exercising the pack up and down some hills and after that forced charge was gone and it was maintaining 19bars.
Moving the seatback in front of the IMA air inlet forwards to allow better airflow may help warming.
After the -20C ordeal, what with all the charging at full SoC, it seemed to have acted like a tonic. The battery seems better now than before.
Other measures taken to enhance drivability in cold weather are as mentioned use of a block heater for warm startup*; cardboard placement in front of the radiator to preserve engine/cabin heat; warm air routed to intake for more lean burn; relocation of the ambient temp sensor to promote auto stop; good grippy LRR winter tires to stay on the road at expense of fuel economy; and such.
*I haven't found need to use the block heater to start the vehicle as a necessity, but warming the coolant makes the windows clear right away for safety sake as well as saves some fuel.
Also to keep the windows clearer in extreme cold at highway speeds I don't use the cabin air recirculation feature of the climate control any more than i have to. I find in those conditions the windows stay a bit clearer of fog with the drier fresh outside air when underway on a long trip.
edit: hope it doesn't get this cold but careful not to hit a really cold windshield all of a sudden with a blast of hot air under extreme conditions to prevent cracking due to thermal expansion.
Old 01-21-2012, 03:27 PM   #4 (permalink)
Originally Posted by AbCaRed00 View Post
Can anyone comment on a good place to find flexible 3 - 4" tubing to do this warm air mod??? I've looked around (home depot, lowes), and can't find anything suitable!
porshuh is offline   Reply With Quote
Old 01-21-2012, 06:31 PM   #5 (permalink)
diamondlarry's Avatar
I found mine at Advance Auto Parts. It is actually a heat riser tube much like what was on my old Ramblers.
Silver '00 MT
85.5 LMPG
Calpod switch
Warm air mod
Grill block
EPS fuse removed
grid charger
OBDII C&C gauge
Old 01-21-2012, 07:08 PM   #6 (permalink)
AbCaRed00's Avatar
Just a note the 4 inch hose was colorized for clarity in the image cited,. closeup showing common black hose used seen here.
It was found at a truck auto parts tool place wayback and leftover.
I used some duct tape to reinforce some sections for wear, i.e. at the side of the plastic engine cover and with wideside of corners.
