New here. 2000 Insight issue - Insight Central: Honda Insight Forum
Old 01-23-2012, 06:35 PM   #1 (permalink)
Default New here. 2000 Insight issue
I just found a 2000 Insight with 140,000 miles. nice shape over all but need a new battery. has plug In power adapter. Guy's asking $2,800 may offer 2k
So what can you tell me about the battery? I guess they sell for 2k, but how hard are they to install? I'm more of a vintage car guy, so I do have some mechanical skills.
- Josh
zgears is offline   Reply With Quote
Old 01-23-2012, 07:12 PM   #2 (permalink)
samwichse's Avatar
If you've got experience maintaining a vintage car, you can mess with the Insight no problem.
Taking out the battery is just a matter of undoing a ton of screws/bolts in the back hatch area and turning off the BIG SWITCH.
I cut my teeth on a 66 VW Bug and then a 70 VW squareback, and while the tech is much different (and not any aftermarket parts), wrenching on the Insight was almost always fun (except all those little trim panel plastic clips! ARGH!).
Sam
Old 01-23-2012, 07:18 PM   #3 (permalink)
What Sam said. Replacing the battery isn't technically involved or even messy/greasy, you just have to take some bits apart.
Old 01-23-2012, 07:43 PM   #4 (permalink)
Is it worth the 2800 he's asking?
Old 01-23-2012, 07:46 PM   #5 (permalink)
If the only thing wrong with it is the battery, yes.
A new battery brings it to $4800, which is still pretty cheap for an Insight.
Old 01-24-2012, 06:10 PM   #6 (permalink)
Code p1449
Old 01-24-2012, 10:30 PM   #7 (permalink)
so is the "subpack"(?) serviceable? if I have one series of bad batterys ?
Old 01-24-2012, 10:56 PM   #8 (permalink)
Premium Member
The person to talk to about battery replacement is Ron from Hybrid-Battery.com. He has two flavors of Battery's that you can choose from, a rebuilt one or a new one called the Better Battery or BB for short. Check out the website and talk with them.
Rush
#2 - 2000 Silver #4095, 185k Miles, 62 LMPG, OBDIIC&C by Peter, GCIM1 by Mike on bat pack
www.TucsonEV.com
Tucson AZ
Old 01-24-2012, 11:00 PM   #9 (permalink)
The strategy is to replace the bad subpacks. We call them sticks.
They're technically serviceable, but it would involve identifying the bad cell(s), cutting them out, and welding new ones in.
Old 01-24-2012, 11:09 PM   #10 (permalink)
There are app. 3,235 posts about the IMA battery here at ICN. Do yourself a favor and try to read most of them. You would be surprised what you can learn....Just a suggestion.
Where is the vehicle located?
