Should I worry if my battery FULLY charges? - Insight Central: Honda Insight Forum
Old 02-03-2012, 05:28 AM   #1 (permalink)
Default Should I worry if my battery FULLY charges?
Hi, I just bought a new insight and I am really happy with it. The only thing I worry about is having to buy a new battery down the road. Should I worry if it charges up all the way sometimes? I thought I read somewhere that it's supposed to stay between 80%-20%. Thanks for your help!
InsightFan is offline   Reply With Quote
Old 02-03-2012, 07:28 AM   #2 (permalink)
diamondlarry's Avatar
The dash gauge, when "full" indicates the 80% you have heard about. Overall, the dash gauge is more of a "this is kind of what's going on" gauge as all kinds of things can be going on in the background that don't show up there. The only way to get a more accurate representation of what is going on with the IMA system is to get an OBDII C&C gauge.
Silver '00 MT
85.5 LMPG
Calpod switch
Warm air mod
Grill block
EPS fuse removed
grid charger
OBDII C&C gauge
Old 02-03-2012, 09:46 AM   #3 (permalink)
racer26's Avatar
Everything to the right of the fuel gauge on your dash cluster is about as useless as tits on a bull. It gives nothing more than a very vague idea of reality, and tends to tell more lies than truths.
Get yourself an OBDIIC&C gauge, or any of the other neat gadgets we've built as a community, and you'll see why right away.
Mods:
CARD switch
John Wayland's Shoebox Sub
Future mods:
Plug-n-Play MIMA?
Economy data miner
Old 02-03-2012, 09:59 AM   #4 (permalink)
Charging up to full all the time or too easily could be a sign of positive recalibrations. Try and watch where the gauge is when you lose regen and it goes up to full. If it's more than a couple of bars, investing in a grid charger would be good.
Old 02-03-2012, 10:20 AM   #5 (permalink)
Or cold weather. Here in Quebec, my gauge is always full, event the last segment is on.
Every morning, it charge to heat the battery pack.
Old 02-03-2012, 10:40 AM   #6 (permalink)
That is true. It does aggressively background charge when the battery temperature is below 32F.
Old 02-03-2012, 03:56 PM   #7 (permalink)
Thanks for the all the help guys!
