Removing/Replacing Front Wheel Bearings - 2000 MT - Insight Central: Honda Insight Forum
Wheel & Tire Center
Old 10-13-2012, 10:29 PM   #1 (permalink)
Send a message via Skype™ to leekujawa
Default Removing/Replacing Front Wheel Bearings - 2000 MT
Anyone here know the procedure (a to z) on how to change a front wheel bearing assembly? Is it easy, difficult?
leekujawa is offline   Reply With Quote Quick reply to this message
Old 10-14-2012, 03:08 AM   #2 (permalink)
You have to unbolt a bit of the suspension to pull the driveshaft which is a bit of a PITA, and it has a large nut on the hub end which can be tight. Not a job for a beginner IMHO.
Pcb's/Built Units for ObdIIc&c, Imac&c, ImaBoost, Current Hacks available. Enqs to 150mpg[at]gmail.com
Old 10-14-2012, 09:38 AM   #3 (permalink)
lach's Avatar
I set out to do that when I replaced the suspension and brakes, but was deterred by the apparent need of a hydraulic press. I passed, but it's still on my checklist. Is it possible to do without a press?
02 Insight posted the FSM on here, be sure to have that on hand since it actually walks you through the Honda-recommended procedures for repairs, including front bearings: Download 2000-2006 Insight Service Manual PDF and Others
If I had my paper copy in front of me I'd tell you the page nubmber, but someone else will have to chime in...
"Donnie" - Red 2000 M/T w/AC #2217, 289,000 miles, 62.2 LMPG, best tank: 84 mpg
Mods: Soundproofing, 5g Civic hatch armrest, JDM Alarm, upgraded stereo with hands-free + USB, LED lighting, rear wiper delete, XM Radio, 3M Crystalline 70%
lach is offline   Reply With Quote Quick reply to this message
Old 10-14-2012, 12:29 PM   #4 (permalink)
Lean Burn = Happiness
jeff652's Avatar
No. I've replaced several Honda wheel bearings. It is not possible to do without a press and several special tools (arbor plates, bearing pullers, and multiple special tools from Honda that I don't know the names to)
Extending the life of your hybrid
Best Tank: 90.2MPG over 918.7 miles 010MCM/030BCM, No MIMA. Details:
2006 Dark Blue Insight. Bought/Selling/Sold/Dismantled nine silvers, three blues, and a Citrus
jeff652 is offline   Reply With Quote Quick reply to this message
Old 10-15-2012, 01:32 PM   #5 (permalink)
I'm thinking buy the bearings, pull the hub assemblies out of the car and take to a machine shop where they can pull out and then press in the new bearings. Will still be cheaper then taking it somewhere for the full replacement job.
I'm at 280K, I wonder how long these bearings will last?
Old 10-15-2012, 01:51 PM   #6 (permalink)
Kevin Dougherty's Avatar
Please post pictures
Kevin
Support Halo Select Auto Parts
Text Brents Mom419-460-436 seven
Kevin Dougherty is offline   Reply With Quote Quick reply to this message
Old 10-16-2012, 01:16 AM   #7 (permalink)
Well right now I think they are okay, that is why I'm wondering how long they last? I've read several folks on forum post that they had to get one replaced. I'm guessing it is very conditional upon your driving conditions in terms of how soon it will fail.
Old 10-16-2012, 01:20 AM   #8 (permalink)
jeff652's Avatar
Yeah it's just an 'if they fail' type thing. The way to test is jack up the car and grab the top and bottom of the wheel. Then try rocking the wheel in and out. Any free play points to bad wheel bearing. Don't grab it on the sides there is some normal play on the steering rack that will give you a false failure indication.
Old 11-12-2014, 11:26 PM   #9 (permalink)
davenm's Avatar
An old thread, but it seemed like the right place to ask:
Are the bolts holding the knuckle to the struts eccentric like on some VWs?
The service manual recommends checking and adjusting (if needed) the front wheel alignment after replacing the front bearings, so this suggests that there is a possibility of altering the alignment when doing this job.
Silver 2006 MT #531
195K miles
Genesis One GCO1 Charger, OBDIIC&C v0.81, MIMA 070 PnP, GAZ rear shocks, KLR3CYL rear springs and belly pan
davenm is offline   Reply With Quote Quick reply to this message
Old 11-13-2014, 12:55 AM   #10 (permalink)
Willie Williford's Avatar
There are just std. bolts with a little play. IIRR
Use: 393,000 mi. @ 58.2 LMPG.
Random Question
