I wouldn't worry about it. Isn't the starter & alternator the same thing? If it had stopped working, you'd have a car with a discharged 12volt battery and no working radio, wiper, etc.
both blue and silver,
No, the Insight has no alternator. Its 12 v. starter is just a normal starter motor. The 144 v. IMA motor is also a generator. As a motor, it can start the engine or assist the engine in moving the car. As a generator, it can recharge the 144 v. battery pack while decelerating the car.
Aloha,
Art Isbell
2000 Insight A/C #559
So is it recommended to occasionally start with 12v just to keep starter from freezing? (Flip IMA switch, start a couple times, and return switch to normal ON position). I have a 2010 EX and have never had the 12v start the car. Any problems with my scenario?
Just disconnect the 12V battery overnight. The computer will "forget" the SOC of the high voltage battery and assume it is zero. Then it will use the standard starter. That's how my 2002 worked whenever I left it sit too long and the 12V battery had died.
You are posting that question on the G1 forum, You might try the G2 forum, Some people don't read all the threads, just those that pertain to their model.
Use: 321,000 mi. @ 57.8 LMPG
