DC-DC Conversion with Key Off - Insight Central: Honda Insight Forum
Old 11-13-2012, 08:05 PM   #1 (permalink)
Default DC-DC Conversion with Key Off
Does the DC-DC converter charge the 12 volt battery when the key is off. Saw some strange signs that it does, but thought it didn't.
Old 11-13-2012, 08:48 PM   #2 (permalink)
Mario's Avatar
From what I've read in the manual, I'd say no. Off is off. In fact, if you turn the key to I, you can see the battery light come on, meaning it's not being charged. I'd guess it wouldn't be charged while it was off, too.
Mario is offline   Reply With Quote
Old 11-14-2012, 02:52 AM   #3 (permalink)
No it doesnt. Off is off
Old 11-14-2012, 03:30 AM   #4 (permalink)
The HV contactor must be engaged for the DC-DC to draw current from the battery. Strike 1.
If the HV contactor is not engaged, the engine must be running to supply current from the IMA motor. Strike 2.
And finally, if the ignition isn't on, the DC-DC has no 12V power of its own, and thus cannot power up. Strike 3.
So in short, no.
503-730-8786
info@bumblebeebatteries.com
Old 11-14-2012, 07:20 AM   #5 (permalink)
highwater's Avatar
Originally Posted by jime View Post
Saw some strange signs that it does.
But we would like to hear anyway.
Randall
MIMA #005
highwater is offline   Reply With Quote
Old 11-14-2012, 04:26 PM   #6 (permalink)
Randall
Yep, inquiring minds like to know.
It wasn't an academic question. I thought I had seen a case where a dome light was left on and both 12v and IMA batteries were discharged. Must have been wrong.
Like Eli says, three strikes - you OUT!
