Gen1 CVT filter and oil - Insight Central: Honda Insight Forum
Old 11-17-2012, 10:28 AM   #1 (permalink)
rodhower's Avatar
Default Gen1 CVT filter and oil
I called our local Honda dealership in Akron, Ohio and asked him for the cost of a CVT filter - it was $17.49 but he didn't have any in stock. In fact, Park Honda at Interstate parkway has NEVER even sold a CVT filter, and none of the Honda dealers in Ohio had one in stock! They did have a synthetic blend oil for $8.75 a quart. I asked him who makes the oil and he said Conoco Philips (I've seen Mobil one mentioned on this forum). So, does anybody think a pure synthetic would be better? Any suggestions on what type of oil others have used?
Thanks,
Rod
2004 Silver Insight with a CVT and 89,000 miles.
rodhower is offline   Reply With Quote
Old 11-17-2012, 10:47 AM   #2 (permalink)
Need4Speed's Avatar
When you say "CVT filter" are you talking about an oil filter or the filter for the CVT transmission fluid?
If you are talking about the cvt trans filter make sure you put in only the correct Honda cvt fluid. Do a search on this site. A number of years ago Honda changed it, had numerous problems, then changed it back. Only use the Honda cvt fluid.
If you area talking about an oil filter for your cvt I think that there is no difference in the oil filters for the cvt and 5 speed. I have also heard that another Honda filter (civic?) will fit and is larger and holds more oil.
2001 Red CVT
Email dave@groe.us
Need4Speed is online now   Reply With Quote
Old 11-17-2012, 01:20 PM   #3 (permalink)
Yes the Civic oil filter will fit, I think the only civic filter that is different is the S2000.
Maybe 3-4 oz. more oil capacity, but it is definately larger.
Use: 320,000 mi. @ 57.8 LMPG
07 FIT "S"
(3K made, The prototype one?)
Old 11-17-2012, 04:01 PM   #4 (permalink)
rodhower's Avatar
I'm talking about the filter for the CVT transmission. Looks like I should stick with the default Honda transmission fluid.
Thanks
Old 11-17-2012, 04:33 PM   #5 (permalink)
ok-insight's Avatar
There is also a filter in one of the lines going to the transmission cooler. ImageUploadedByAG Free1353187922.697861.jpg
I took a picture of it when I did the transmission service. If you're going to be in there you might as well change that one too.
Sent from my iPhone using AutoGuide.com Free App
ok-insight is offline   Reply With Quote
Old 12-17-2012, 01:13 PM   #6 (permalink)
Default CVT Filters
My 2004 Insight CVT has 2 filters. Both will require lowering the pan (no biggie). A canister type filter and a flat filter Honda calls a strainer. I have had my pan down a couple of times now and the gasket could be reused but that would not be the time to find out you need a gasket so better have one just incase.
There are a few magnets in there that should be examined for metal bits and then cleaned off. Any of the CVT fluids will work but may have startup clutch engagement issues. I would recomend the Honda CVT fluid and not put more than 20k between changes and 60k on filters.
MLN63 is offline   Reply With Quote
Old 12-18-2012, 10:10 AM   #7 (permalink)
scootr06's Avatar
To clarify, there's 1 filter and the strainer inside and another filter in the line to the tranny cooler? I've changed the cvt fluid every 15k miles or every 2 yrs....now at 45k miles and have yet to change any filters. Thx for the info!
scootr06 is offline   Reply With Quote
