So Many Problems, What Should I Fix First? - Page 2 - Insight Central: Honda Insight Forum
Old 11-19-2012, 01:02 PM   #11 (permalink)
Originally Posted by Willie Williford View Post
Mitch:
Don't forget the coolant and hydraulics (brake/clutch) fluid change.
Good Call,
I forgot about the clutch. I'm going to need to find a friend to help bleed the brakes and clutch.
Thanks,
Mitch
2000 Insight MT
240,000 Miles
inblackwell is online now   Reply With Quote
Old 11-19-2012, 01:25 PM   #12 (permalink)
3-Wheeler's Avatar
Originally Posted by inblackwell View Post
Good Call,
Thanks,
Mitch
If you get a MightyVac or similar you might be able to do them yourself.
Jim.
3-Wheeler is online now   Reply With Quote
Old 11-19-2012, 01:47 PM   #13 (permalink)
It can be done by yourself but a little harder to do.
They sell "one person bleeder kits" at most automotive parts houses.
Use: 320,000 mi. @ 57.8 LMPG
07 FIT "S"
(3K made, The prototype one?)
Old 11-20-2012, 05:16 PM   #14 (permalink)
Default and don't forget ...
Honda spec Blinker fluid ...
Caspar Dioge is offline   Reply With Quote
Old 11-20-2012, 05:57 PM   #15 (permalink)
Haha...very helpful. Thank you.
2000 Insight MT
240,000 Miles
Old 11-26-2012, 10:36 AM   #16 (permalink)
Default Replaced Cabin Air Filter
Update:
Replaced the cabin air filter. Really not a pressing issue but it was quick and easy. Old filter was amazingly dirty/disgusting.
2000 Insight MT
240,000 Miles
Old 11-26-2012, 12:44 PM   #17 (permalink)
The longer you leave a HEPA filter in place, the better filtering it does! LOL. I never replaced the cabin filter in my dodge either... I bet it looks almost as bad. I only spend money on things that keep the car running (oil change, fluid exchange, etc) not stuff that I can live without like A/C or cabin filters.
I view a car the same way I view my computer and television (keep it til it dies then dispose). I suspect your previous owner was the same.
both blue and silver,
Old 11-26-2012, 12:55 PM   #18 (permalink)
Funny. That's one way to do it. I'm not judging. I'm the opposite. I replace my computer almost every year. Sell the old one before its worthless and put the money towards the new one.
2000 Insight MT
240,000 Miles
Old 11-26-2012, 12:59 PM   #19 (permalink)
Default Update: Replaced Front Brakes
I just replaced the front brake pads and rotors. It appears that it was a good idea. The brakes felt okay but judging by the wear pattern I think there were some serious issues. I'm not familiar with Insights but I've done a few brake jobs in my time. Those old pads and rotors don't look right. That's not how healthy Insight pads and rotors wear is it?
2000 Insight MT
240,000 Miles
Old 11-26-2012, 01:15 PM   #20 (permalink)
There you go again Mitch, The results of owing a car from the "salt zone".
The Insight takes very little front brake pad contact to stop. (Remember Regen)
The pads look pretty worn out. Did you ever get the "screeching" of the wear indicator tab?
Good job, keep it up.
07 FIT "S"
