Any Grid Chargers in the DC area? - Insight Central: Honda Insight Forum
Old 12-01-2012, 01:54 PM   #1 (permalink)
Default Any Grid Chargers in the DC area?
My 2001 (40k on a replacement battery) just started giving IMA errors.
Does anyone in DC have a grid charger? Before I put any more money into this car I'd like to see if grid charging helps, or does it need a new battery.
If anyone has one they would let me borrow I could pitch in a few bucks?
Please let me know...
Ben - Potomac, MD
bartine is offline   Reply With Quote
Old 12-04-2012, 11:58 AM   #2 (permalink)
Is there anyone who provides Grid Charging services within 200 miles? I would pay to get it charged to test how the battery responds.
I like this car, but at close to $1,000 for a top of the line grid charger, I could pony up a little more and get a new battery.
It has not proven to be hugely dependable - water leaks, transmission, problematic battery. But - it is very satifying to drive. Economical and pleasant.
I really would like to try to fix this, but is it worth it to gamble on a grid charger that might not solve the problem?
Old 12-04-2012, 12:56 PM   #3 (permalink)
samwichse's Avatar
You could make a dumb charger for very cheap...
Grid Charger Power Supplies
2 cheap power supplies at $12 each plus the 1 amp diode, an old computer PSU case, some wire nuts, and some molex connectors... all in all, less than $50 if you can do it yourself.
So cheap I was thinking about building one "just in case" even though I don't have anywhere to plug it in!
If the cheap POS grid charger helps, then you could think about a fancier Genesis charger from Mike with "set it and forget it" convenience and faster charging rates, etc.
Sam
-OBDIIC&C
-IMAC&C
-Lower grill block
samwichse is online now   Reply With Quote
Old 12-04-2012, 01:00 PM   #4 (permalink)
samwichse's Avatar
90v led power supply | eBay
Quite a few choices on US ebay.
-OBDIIC&C
-IMAC&C
-Lower grill block
Old 12-04-2012, 01:40 PM   #5 (permalink)
You need three power supplies as you should power the 12V fan as well when charging.
Old 12-04-2012, 09:26 PM   #6 (permalink)
TopFuelTim's Avatar
Default Grid charger is not too difficult
Hi Ben,
Glad to hear from you again. I didn't know you had moved away from Georgia.
Like Jeff said, you can build a dumb charger pretty cheap by following the directions you can find on this website. I have already built two. One is a multi-voltage model just to see if I could do it, and another that I just gave to my son uses two 90V LED power supplies. I had around $70 total in that one. I have learned that grid charging definitely helps extend the life of a battery. However, two of mine got to the point where I had to grid charge every day to keep them going, so I finally gave in and rebuilt them. Now that was a learning experience!
Also, Jeff652 sells a good simple charger if you are interested in that route. I do like Mike Dabrowski's Genesis GC01 that I used to grid charge your car very much, especially with the discharger option that I got in May, but realize not everyone needs that. With three Insights, however, the GC01 has been indispensable.
Warning, blatant plug to follow:
In case you might be interested in getting rid of your car cheap, I might be interested. My son just bought the one I fixed up.
Take care,
Tim Glover
Old 02-14-2013, 07:43 PM   #7 (permalink)
Originally Posted by bartine View Post
Ben - Potomac, MD
I'm in Potomac too. If you want to sell the car, post it here first.
atikovi is offline   Reply With Quote
