You need:
2 airbags (some states require new ones - others don't care)
Note that the interior color is different for 2005-2006 and 2000-2004, so earlier than 2004 may be the wrong color for the passenger bag.
You need the airbag computer (mounts behind the console) - new $600, junkyard (from a non-wreck) $50
You need the steering wheel "clockspring". The wheel airbag destroys it. It's about $40 new.
You need both seatbelts. They have pretensioners that fire if the airbags go off and they cannot be reset. $275 each new, $75 each junkyard from a non-wreck. Make sure they extend and retract - if they are locked, they are from a wreck. Also, the color of the belt changed in 2005.
You probably need a new windshield and rear-view mirror.
Originally Posted by zgears
I just got a a low millage 05 that was in a low speed crash. I plan on replacing the deployed airbags. Is anything involved other than replacing the air bags, like sensors or controller? Is anything else one time use?
