Superbrain 989 - Insight Central: Honda Insight Forum
Old 01-02-2013, 11:56 PM   #1 (permalink)
Default Superbrain 989
I've been trying to read all of the threads about grid charging and what is needed to build your own charger. I've seen several topics about the superbrain 989. I have some questions about this and grid charging. First, can the 989 be used as a grid charger since it can do up to 25 NIMH cells at one time? If so can you build a harness for it or do the batteries have to be removed from the car? Does anyone have step by step instructions in how to build a grid charger. I can't decipher an electrical schematic. And I mean a fairly simple one. Please give me a simple lesson on grid chargers. I just had my batteries replaced under warranty, but the car will be out of warranty the next time it happens so I would like to have a grid charger to help make them last. Thanks for your help.
Mark
austexcat is offline   Reply With Quote
Old 01-03-2013, 12:23 AM   #2 (permalink)
You've come to the right place.
Not in the context you're thinking; the Insight battery has 120 cells inside of it. See below.
The batteries must be removed from the car.
Step by step? No, unfortunately not.
Then you likely shouldn't attempt to build one yourself. Sorry.
Mark
Give us a call, we'd be happy to discuss your grid charger options.
Basically, there are two options available.
1) Set it and Forget it; The Ronco appliance of grid chargers. www.99mpg.com
2) Dumb, in an endearing, Forrest Gump type of way. Often misunderstood and probably better left for the more technically minded. www.hybridautomotive.com
Avoid the insanely priced one on eBay, if it's still there.
503-730-8786
info@bumblebeebatteries.com
Old 01-03-2013, 02:38 AM   #3 (permalink)
Hey ELI you spelled "hybridautomotive" wrong, or was that on purpose.
Use: 320,000 mi. @ 57.8 LMPG
07 FIT "S"
(3K made, The prototype one?)
Old 01-03-2013, 02:07 PM   #4 (permalink)
Whoops, nope, typo.
503-730-8786
