How much does Autostop really save? - Page 5 - Insight Central: Honda Insight Forum
Old 01-05-2013, 04:47 PM   #41 (permalink)
Originally Posted by theaveng View Post
I also disabled autostop (yesterday) by keeping the car in first gear and engine idling. So far I've not noticed any change in this tank's MPG average.
ok you can ignore my previous post ....
I'll repeat it anyway... here...
Originally Posted by bibendum View Post
to explain how much it saves you may want to consider how much
fuel it uses at idle per minute.
If you take my guess that gasoline fueled engines burn fuel
at the rate of 8 oz per horsepower-hour...
and that an insight at idle is using 4 horsepower?
one hour at idle is a quart of fuel
or about 1/2 oz per minute.
( I think this is a low side guess. idle seems to use more fuel)
you log how long you sit at idle per tank.
your answer will be obvious.
victor
bibendum is offline   Reply With Quote
Old 01-05-2013, 04:54 PM   #42 (permalink)
Originally Posted by dandism View Post
You're wasting gas, creating emissions, and adding extra wear to your engine. Why do you want this? Is The Citrus Smoothie right?
No I'm not a troll. I'm an engineer and engineers question everything, especially when it comes to machines & their operations. I've been contemplating what to say, but no matter what I utter, you will probably condemn me. I'll just point out:
- my car only stops twice per trip (a light when I enter the interstate & a second light when I exit)
- so we're only talking about 30-40 seconds of idle stop that is not happening
- my idling engine uses just 0.15 ounce per minute (approximately)
Out of the ~2/3 gallon or 85 ounces I burn on that trip, I'm wasting 0.08 ounce with my little experiment. Or one-tenth of a percent.
both blue and silver,
Old 01-05-2013, 05:35 PM   #43 (permalink)
one more bit of information....
how long in minutes or miles is your interstate trip?
you might sit at idle for a minute and 20 seconds each way
so using your own numbers the most you will spend per trip
is a half an oz of fuel.
or about a quarter a mile lost in the worst case scenario.
if you are like most people you will not notice around 2 to 3 percent.
so I am thinking your trip on the interstate is more than 12 miles
one way on my commute, I can sit for 12 minutes at lights.
most days it is around 5 minutes.
most days I run for 40 minutes and I do notice the difference with autostop.
victor
Old 01-05-2013, 06:13 PM   #44 (permalink)
No I'm not a troll. I'm an engineer and engineers question everything...
An engineer who questions everything gets nowhere. If you're going nowhere, you're going to want auto-stop.
But seriously, if you only have a few stops in your daily trip then auto-stop won't have a large impact, but I still don't see why you would want to disable it.
dandism is offline   Reply With Quote
Old 01-05-2013, 09:27 PM   #45 (permalink)
I find when I disabled it it makes the heat warmer, the ac cooler, clutch engagement smoother on the cvt and if you are in the cycle of a negative recal it emerges from it faster.
Plug you can lift from the brake petal lightly and creep upwards to trigger lights.
Old 01-08-2013, 02:35 PM   #46 (permalink)
Since someone suggested measuring my time spent stopped, I did that in a previous post. It is about one-tenth of a % more fuel burned per trip to work (if the engine is left running at stops). About 1/10th of an ounce of gasoline wasted.
I don't mean to insult you, just to point out how your posts appear to others. To me, you do behave "troll"..... You don't ask advice and don't know enough to offer it. You provoke us with "research" and then argue. Most of what you say is either against our conventional wisdom, or against Honda's guidelines.
Conventional wisdom is often not wise at all (and sometimes flat wrong). By the way I question the very existence of God. I also question that Honda is godlike in their knowledge or that I should just blindly follow them. They've made mistakes in the past.
I think people should learn to be more tolerant of others, even if they think it's wrong. TOLERANCE is the key to human beings getting along with one another, especially when humans come in so many different flavors (american, european, asian, african, christian, jewish, muslim, buddhist, young, old, middle, engineers, not engineers, Doubting thomases, loyal followers, et cetera). I am in the doubting thomas category. I question everything. By the way I've owned an insight since 2002, so I have as much to contribute as any other driver who has owned one an equal amount of time (though I've driven fewer miles). I am not going to hold back my opinion or thoughts.
In any case, even if I annoy you, there's no call to act like a high school or college student and start using names like "troll" or "A-hole". The moment you reach adulthood, you should stop with the name calling and resolve the differences as an adult would. Not with hate or insults.
Old 01-08-2013, 02:59 PM   #47 (permalink)
Mark Elvin's Avatar
The way I see it is it has to save SOME fuel or Honda, with their wealth of knowledge, wouldn't have bothered with fitting it.
I suspect it may have been the 'magic ticket' that took the Insight to 80g/100km
Sent from my GT-I9100 using AutoGuide.Com Free App
2003 Quantum Grey G1 Insight
83.5 LMPG
25,500 Miles
IMA C&C (to be fitted)
ODBII C&C
Mark Elvin is offline   Reply With Quote
Old 01-08-2013, 05:38 PM   #48 (permalink)
Indeed. NEDC has a large amount of stop periods where it effects the measures CO2 average over the cycle.
I don't think it's the best thing for the thrust bearings mind you.
Sent from my iPhone using AutoGuide.com Free App
Old 01-08-2013, 05:45 PM   #49 (permalink)
Good question as the later Insight and HCH claims cylinder deactivation. Its documented the HCH runs on as little as 1 cylinder, but we dont know the gallon per hour usage. I see it on the newer Insight and the scion xa I had that uses the same engine as the prius 2 and the scion uses about .4 less fuel an hour than the newer insight.
On the other hand my Insight idles a lot and it seems to have little effect on mpg vs non hybrid cars. For example when I had a ford focus with the wing and + sized wheels a few years ago when mines was wrecked, it got 17 mpg first tank, where as my insight got 50+
Old 01-09-2013, 10:21 AM   #50 (permalink)
I'm surprised the Scion only gets 38mpg on the highway, and not closer to the Prius2 economy of 45. Maybe because the Scion is not using the Atkinson cycle.
