Insight CVT? anyone have problems? - Insight Central: Honda Insight Forum
Old 02-15-2013, 03:36 AM   #1 (permalink)
Default Insight CVT? anyone have problems?
considering adding a 2006 CVT insight to keep my 2000 MT company
Not sure if this problem bleeds into the insight, but the 1st gen civics with CVT had massive problems and numerous recalls, (honda running a large scale experiment) anyone see similar issues with the insight CVT?
also, any un-moddedCVT owners able to get north of 60MPG or is that just a dream?
your thoughts appreciated
thanks!
thomas is offline   Reply With Quote
Old 02-15-2013, 06:27 AM   #2 (permalink)
Need4Speed's Avatar
There are numerous reports of the cvt puking, typically over 200k miles. Mpg depends on your driving style, terrain, traffic, etc. my worst tank was over 59 mpg, best 78 mpg. With the cold temps the past two months I can only get 65 mpg. Compared to other cvt owners I think my drive allowed me to get higher than normal mpgs.
2001 Red CVT
Email dave@groe.us
Old 02-15-2013, 06:58 AM   #3 (permalink)
My 2006 started making "noise" at 250,000 it got progressively worse for the next 30,000 miles. So I changed it out with a 2004 with 80,000 miles on it. I took the transmission apart and could only find some "rubs" between the driven clutch basket and the apposing "Phonic wheel" , no bearing problems and everything else looked OK. As parts are not available I packed it up and put it in my "projects pile"
Old 02-15-2013, 07:09 AM   #4 (permalink)
jc2bg's Avatar
Default Cvt
Umm, no offense, but some car owners might find 250K noise-free [and apparently trouble free] miles sort of good for a transmission.
2013 Insight EX (w/o nav) -- Findlay, Ohio
jc2bg is offline   Reply With Quote
Old 02-16-2013, 05:16 AM   #5 (permalink)
wow pretty impressive stats needforspeed, rivals what i get on my 2000 MT. maybe the CVT isnt all that bad.... im pretty happy if i can get north of 60 on a CVT. well if it gets over 200k thats legit, the civics get like 60k then get the classic judder and eventually fail.
Old 02-16-2013, 07:36 AM   #6 (permalink)
Need4Speed's Avatar
I suspect that with a manual I could get another 15 mpg over my cvt.
2001 Red CVT
Email dave@groe.us
Old 02-16-2013, 10:31 PM   #7 (permalink)
eq1
eq1's Avatar
I've read at least half a dozen posts, maybe more, of people complaining about noisy CVTs, most often a "growling" noise, and then, about the costs, difficulty of repair or replace... I drove one CVT with such a noise, really unbearable. But then, I think I saw one or two posts about how the CVTs are reliable and strong if you take care of them, change the fluid at the correct intervals...
2000MT, CAN, ~168K miles
Old 04-12-2013, 11:48 PM   #8 (permalink)
juntjoo's Avatar
in 13 years no one has rebuilt one of these and made a write-up?
Sent from AutoGuide.com Free App
juntjoo is online now   Reply With Quote
Old 04-13-2013, 06:23 AM   #9 (permalink)
Need4Speed's Avatar
Here is the most promising thread on rebuilding the cvt:
Does anyone rebuild the CVT"s (automatic trans)?
2001 Red CVT
Email dave@groe.us
Old 04-13-2013, 05:09 PM   #10 (permalink)
I finally fully dissembled mine and could find no "failed" parts. the only issue was noticeable end play on the main shaft caused by wear in the "key slot" in the indeterminate case allowing the shaft to transition laterally enough to allow contact between the phonic wheel and the clutch drum. If it happens again I will run it to failure, which I think will take a long long time.
