Originally Posted by friar75
I am locate in Western N.Y. I know of one, Chris, i Gasport, NY. I am also looking to install a grid charger.
Welcome.
Probably your best option on the EGR is to buy one of Jeff562 reconditioned ones. The Acura would work if you can find a good one, but I hate to spend time putting on bad parts
You probably also need to clean the EGR plate, located between the intake manifold and the cylinder head. Use lots of penitrating oil to soak the bolts before trying to get them off. A broken bolt is a real disaster. You can test the EGR system as a source of rough running by just disconnecting the EGR valve plug. If your rough running clears up, then it is most likely the valve or plate.
Your can edit your signature to provide a bit of location data within the signature or the avatar. Go to "User CP" above. A location will allow your posts to perhaps connect with others who are fairly close.
