Have YOU deep discharged your pack yet? - Page 21 - Insight Central: Honda Insight Forum
Wheel & Tire Center
Old 04-20-2017, 11:25 PM   #201 (permalink)
S Keith's Avatar
Originally Posted by esprout View Post
Correct, 2.4V over 189.21 hours averaging to 12.7 mV/hour self discharge in that period.
That period actually starts at 2,255.08 hours with 163.2V right after parking the car. So 4.2V over 212.75 hours is 19.7 mV/hour. But voltage drops fastest right after parking the next 12-24 hours.
Drove the car this evening over some hills. It negative recal once up a longer hill as expected as one or more tap voltages drop out. But no CEL/IMA, so performance has not degraded in 9 days storage.
The maximum charge voltage observed is 185V, 4V less than 189V I've observed on my friend's Insight. I may need to dig up an appropriate power supply for the fan and hook it up so I do a full balancing grid charge and see if that top balances the cells, and enables higher peak charge voltage.
Thanks for the clarification. Your bolded statement is not correct. A recal is an indication of a problem with battery imbalance due to the taps dropping out as you correctly note. A tap dropping out after 9 days is likely due to excessive SD that manifests itself under load and doesn't register at rest.
In short a recal after a 9 day sit is because it sat for 9 days, and there is some underlying issue. I have let our '05 G1 sit for 6 weeks. It did not recal. It has a 2 year old "new" Honda battery (bought that way).
You have a tendency to cherry pick your data when drawing conclusions, i.e., "I did these 7 things to the pack, and it's clearly this 1 that did it even though the first thing I documented contradicts it, and I'm willing to point to this one thing and say that's it."
The 22 day deep discharge may have been effective, but you don't have isolated data/results to compare, and your initial flattening of the battery pack with subsequent crappy SD response suggests more may be necessary than just a deep discharge.
What you have now is a documented process and a relatively well known state of the battery - significantly improved from day zero. Take it up a notch. See if the well-followed reconditioning process improves the pack further. Conduct the cycles, drive the car around for a few days, let it sit for 9, record data, see if anything changes, take it for the same drive and see if it recals.
Or don't.
'05 G1 CVT w/192K mi as of 7/2016; '02 G1 CVT w/182K mi as of 7/2016 (P1449 HR pack); '06 HCH2 #1 w/145K mi as of 7/2016 (SOLD!), '06 HCH2 #2 w/223k mi as of 2/2016 (SOLD!); '03 Prius w/166K mi - Pack rebuilt with Gen2 modules; '08 Prius w/135k mi as of 7/2016; '07 Prius w/185k mi as of 7/2016
Old 04-20-2017, 11:32 PM   #202 (permalink)
^I clearly stated in my conclusion:
The pack capacity is still poor with easily triggered recals, and is undoubtedly permanently reduced. But the pack balance seems quite good, and self-discharge levels reduced to a point where CEL/IMA is no longer triggered. I'll be taking the car for a drive later today to see if it stays well behaved enough to avoid CEL/IMA after the last 9 days sitting idle.
With that performance level as baseline after the 22 days extended deep discharge, the pack has maintained the same performance since after 4 cycles of sitting around 7 days, 5 days, 6 days, and 9 days.
I'm not cherry picky my data, you are not paying attention.
2004 HCH1 180k, 2001 I1 208k, tooting around bay area, CA
Old 04-21-2017, 12:03 AM   #203 (permalink)
S Keith's Avatar
You contradict yourself. "Pack balance seems quite good." Recals are evidence of the opposite. You still lack some fundamentals.
I am paying attention. You just can't see your own errors/bias.
Random Question
