Any recommendations for replacement tires? - Page 2 - Insight Central: Honda Insight Forum
Old 01-27-2005, 01:20 PM   #11 (permalink)
Default Any recommendations for replacement tires?
I have only had my car for 5 days. It's a 2000 with 32K miles on it. It has the Sumitomo tires 175/65/R14. I have nothing to base a comparison, but I checked their pressure and they were at 48lbs. I think they have a fairly rough ride, but I expected it to be that way. Since I purchased the car from a used car dealer, I wan't able to talk to the previous owner (yet).
I drive 49 miles each way to work from Spartanburg SC to Near Charlotte NC on Interstate 85. There are some very long grades, and almost nowhere is it flat, but I am experimenting with driving styles and mileage.
I was able to get 72.3mpg by driving carefully trying to run 55, but on the long grades ending up around 49-50. I would downshift on some of the other grades when the FCM would drop from 75 to less than 50. I don't know if I'm doing it right, but it seems like I am not sacrificing as much that way. If I speed up to 60, the mileage drops about 4 or 5 mpg and if I go to 65, it drops to 59-60. Going 55 adds about 7 minutes to my commute.
Maybe there is someone near that might want to trade wheels for a week or two to do a direct comparison.
robert
Robert Frost is "The original Bad Bob, not Dirty Bad Bob from New Mexico."
From the "Life and Times of the Judge Roy Bean"
2000 Citrus #2757 206,000mi.
originalbadbob is offline   Reply With Quote
Old 04-16-2012, 03:37 PM   #12 (permalink)
Hey can anyone PM me a link to buy the OEM tires. Everything that I see online has each tire at about 92-100 dollars.
thanks
drewbplayer is offline   Reply With Quote
Old 04-17-2012, 12:31 AM   #13 (permalink)
Ditto. I would love to find the Bridgestones at that price.
macarose is offline   Reply With Quote
Old 04-17-2012, 12:36 AM   #14 (permalink)
Yea I know. The lowest so far is like 356 including shipping that a guy mention above. It was 80 per tire plust like 35 for shipping if my math works out. Either way this is not 45-50 that some people were discussing. Oh well if anyone finds them any cheaper let me know.
Old 04-17-2012, 02:14 PM   #15 (permalink)
racer26's Avatar
I doubt you will. The poster above is wrong.
RE92's are worth $80-100/tire installed, BUT, the fuel economy bonus they give over ANY OTHER TIRE makes it more than worth the extra $100-200 over the long run.
To put any other kind of tire on thinking you're saving money is nothing but shortsighted.
If you want to put other tires on for a softer, smoother ride, or more cornering grip, or some other reason, then fine. Just don't think you're going to save money by doing it.
Mods:
CARD switch
John Wayland's Shoebox Sub
Future mods:
Plug-n-Play MIMA?
Economy data miner
Old 04-18-2012, 09:44 AM   #16 (permalink)
Default Tyre size
Please check, Insight tyres are typically 165/65R14. not 175.
London UK.
Old 04-18-2012, 04:43 PM   #17 (permalink)
diamondlarry's Avatar
Actually, the above poster was probably correct when it was posted...nearly 8 years ago.
Silver '00 MT
85.5 LMPG
Calpod switch
Warm air mod
Grill block
EPS fuse removed
grid charger
OBDII C&C gauge
Old 04-28-2012, 02:33 PM   #18 (permalink)
Nina's Avatar
What would you do:
Dealer quotes:
"We sell the Bridgestone Potenza165-65/R14 RE92 "low rolling resistance" tire for your Insight. These tires are designed to give your Insight the best gas mileage.
The tires are $109.00 each. With tax, mounting, balancing and Calif. disposal fees each tire would be $142.00.
These tires are available now and also come with a 1 year or 12,000 limited road hazard warranty."
Wheel Works quoted $90.99 per tire. I don't have my notes on what the total per tire would be in the end.
I've used both places for years with my CRX and another car at Wheel Works, too. I'm inclined to think that the additional $80 for the 4 tires charged by the dealer would be worth it for their experience with Insights.
I'd try to work a 'long time customer' discount with both of them. This would be the first work since I purchased it recently.
What do you think?
Nina is offline   Reply With Quote
Old 04-28-2012, 03:15 PM   #19 (permalink)
Kevin Dougherty's Avatar
Originally Posted by Nina View Post
What would you do:
Dealer quotes:
What do you think?
Costco runs Bridgestone / Michelen sales on a rotating 2 month basis
My out the door price Re92s 165/65/14 ; mounted, balanced, etc. last week was four tires... $382
kevin
Old 04-28-2012, 04:09 PM   #20 (permalink)
aisbell's Avatar
Firestone tire centers will usually match Costco's sale price. So if Costco isn't convenient or you're not a member, check your closest Firestone tire center.
Aloha,
Art Isbell
2000 Insight A/C #559
