2010 insight worth it. - Insight Central: Honda Insight Forum
Wheel & Tire Center
Old 02-17-2017, 08:27 AM   #1 (permalink)
Default 2010 insight worth it.
I'm going to a dealer soon to look at some cars and one of the ones I'm interested in is the 2010 insight for $5,995 it's has 127k miles on it and was wondering it if would be worth it to buy I am mainly concerned about how long the battery will last. Also I've heard that the insight burns through oil very fast is that true?
Thank you for your time.
Nvaughn91 is offline   Reply With Quote Quick reply to this message
Old 02-17-2017, 10:29 AM   #2 (permalink)
RedDevil's Avatar
Welcome.
That offer sounds reasonable.
The oil consumption issue is limited to 2012 and early 2013 Insights. A 2010 will not lose any oil at all.
Hybrid battery failures are highly uncommon with the second gen Insight, maybe a couple from very hot climates.
Mileage is no concern for the battery; long periods of disuse is.
The OEM 12 Volt battery is a known weak point. Have it replaced when you are in doubt, monitor its voltage anyway. But they are cheap.
I expect a 2010 to be already on its second 12V battery.
Make sure the service history is complete.
Check for CVT fluid changes and the spark plug change. The Insight uses 8 iridium plugs which last very long but are not cheap to replace.
When you do a test drive check whether the transition from low speed to higher speed (around 10 to 15 mph) and vice versa is smooth. a slight bump is common, a stronger jerking or shuddering is not. These often clear up with a proper CVT fluid change - but not always.
At speed check for a high-pitched whine around 60 mph. Mine does that, while most other Insights don't. You would not notice it with the radio on, it is not that hard - but I'd rather not have that anyway.
When hit with side wind at or above 50 mph there can be a burring sound from the top windscreen seam if that is not tight. Should be an easy fix with kit, but again - better to have one where the seam is tight.
Check out the rims and tires.
The Insight is sensitive to tire pressure, especially when it is lower than standard.
Many find handling improves with slightly higher pressure than the door sticker advises.
185 mm width tires on 16 inch rims are noticeably more precise than 175 width 15s which were OEM to 2010 Insights. The ride is more firm, economy nearly the same.
The Insight horn and halogen low beams are not impressive. I replaced them with an Accord (high tone) horn and cheap Chinese HIDs which works out quite well. LED grids in the dome and boot lights are an easy improvement too.
The Insight is a reliable car, good value for money.
Have a look around, do some searching.
Post a picture when you do buy it
2011 Insight Elegance
Accord horn, Waxoyl, HIDs, Green Oil, UltraGauge, LEDs, full upper&partial lower grille block, aero tweeks, plans for several eco mods
RedDevil is offline   Reply With Quote Quick reply to this message
Old 04-02-2017, 04:58 PM   #3 (permalink)
My 2010 has done that since new.
'10 Polished Metal Metallic I2 LX since Nov 30/10
MacNoob is offline   Reply With Quote Quick reply to this message
Old 04-02-2017, 05:46 PM   #4 (permalink)
RedDevil's Avatar
Originally Posted by MacNoob View Post
My 2010 has done {the high pitched whine} since new.
After 3 years of driving in silence I reinstalled my USB stick with 300 albums the other day. Guess what - haven't noticed the whine since
Old 04-20-2017, 10:57 PM   #5 (permalink)
I got my 2010 @118k km for 11k CAD after tax and all other charges... and yes I live in a country with stupidly high tax the asking price for the car was 9000 I believe
Sent from my iPhone using Tapatalk
2010 Ex with Nav Canada model
MannyK is offline   Reply With Quote Quick reply to this message
Old Today, 08:36 AM   #6 (permalink)
im looking forward to a 2nd 2011 Insight, 60000km.
really do serious homework about Insights, found pros and cons.
is the odometer tamper-proof? that 60000km reasonable for a 2011 Insight?
what other factors should i check when seeing that car?
tama25 is offline   Reply With Quote Quick reply to this message
Random Question
