Battery Vent Seatbelt blockage - Page 2 - Insight Central: Honda Insight Forum
Old 08-20-2009, 06:08 PM   #11 (permalink)
You don't have to move the tucked in belt when folding down the seat since it fits in between the gap. It doesn't constrain the seat from folding down.
You do have to tuck it back in though once you put the seat back up.
corey415 is offline   Reply With Quote
Old 08-21-2009, 10:00 PM   #12 (permalink)
Very good idea....
2010 Honda Insight - Spectrum White EX
dingousa is offline   Reply With Quote
Old 05-06-2010, 09:21 PM   #13 (permalink)
Premium Member
AstroInsight's Avatar
Has anyone in hot climates, where you need your AC often, try to make a small hose from the AC vents to output in front of the IMA bat intake?
This would cool the bat right away and allow heavy IMA useage in hot places?
2010 Insight, Since 05/11 39-65. MPG OD 2400Mi.
MODS:
2. IMA Bat exhaust temp monitor, from Radio Shack,
3. Foam insulation on cold AC pipes.
4. 12V and 100V bat insulation.
5. Inside radiator airflow improvements.
6. Engine belly smoothing.
7. Leading tire skirts enhancements.
PREVIOUS HONDAS: 72 N600, 85 CRX-SI
AstroInsight is offline   Reply With Quote
Old 05-07-2010, 11:12 PM   #14 (permalink)
The cabin air is moved around the sticks. I had bought a piece of pool hose to use the rear drivers side foot well vent as I liked the hvac to foot and vents.
Since I use the auto feature to keep from killing my fuel economy, it doesnt direct ait down there and would be worthless.
Some of the first gen guys have added computer pc fans for extra air flow.
Old 05-13-2010, 11:51 PM   #15 (permalink)
illustration on manual P.299 shows seat belt is covering 50% of intake area so it should be fine i guess...
timmypro is offline   Reply With Quote
