Honda won't issue a Recall on the Wimpy Horn! - Page 8 - Insight Central: Honda Insight Forum
Old 06-30-2010, 05:20 PM   #71 (permalink)
I too was interested in getting the accord horn but it doesn't appear anymore on their website.
pikkashoe is offline   Reply With Quote
Old 06-30-2010, 05:25 PM   #72 (permalink)
See several posts up - Honda won't issue a Recall on the Wimpy Horn!
If you're determined to get it from College Hills Honda, just give them a call (1-888-244-6632) and give them the model number, I'm sure they still have it or can get it despite it not being listed on the Insight-specific accessories page anymore...
Old 07-01-2010, 08:36 PM   #73 (permalink)
Keen4Green's Avatar
I had to use my wimpy horn today to alert an aggressive driver in L.A. (So many here!). It's a joke of a horn but way better than the rubber bulb clown horn that comes on the PT Cruiser!
Old 07-02-2010, 01:58 PM   #74 (permalink)
I used my horn today as well. One of my biggest pet peaves is when you are sitting at a light trying to turn left, then the light changes and you try to clear the intersection and about 5 more people try to race through the yellow which by then turned solid red. Yellow means to slow down and prepare to STOP not punch the accellerator and run through it. So by the time the third person ran the light I just layed on my mighty horn and flashed my lights.
I think the guy that went through the light just laughed his face off when he heard that squeeky little honk. Yup, got to get myself one of those train horns
IndyTom is offline   Reply With Quote
Old 07-02-2010, 06:06 PM   #75 (permalink)
UseTheEarth's Avatar
Default Even a 5 Year Old Girl says its Wimpy
My sweet 5 year old girl laughed at my 2010 Honda Insight horn yesterday.
I am in the market. If its a do it yourself job, I am all over it..
2010 Honda Insight EX/Nav (Tango Red, RoadWire Leather Wrap, Heated Drivers Seat, XM, Remote Start, 3m Film)
2003 Honda Odyssey EX-L RES
http://www.fuelly.com/sig-us/39574.png
UseTheEarth is offline   Reply With Quote
Old 07-02-2010, 10:44 PM   #76 (permalink)
It takes about 10 minutes to swap the horn to an Accord Horn.
It's actually about 1 decible quieter but sounds a lot better.
Here is a link to the part or you can buy it at your local dealer:
38100-STK-A02 - Honda HORN ASSY. (LOW)
Old 07-02-2010, 10:48 PM   #77 (permalink)
Oh, I forgot.... here is the link to the Video Podcast that shows you how to install it. Very easy plug and pray... um.. I mean play.
DIYHonda.com Video Podcasts: Episode #163 - 2nd Generation Honda Insight Horn Upgrade
If you want something louder you may have to do some splicing and dicing.
I am thinking of getting a Wolo Bad Boy Horn.
WOLO MFG. CORP. AIR HORNS, AIR HORN ACCESSORIES & AIR COMPRRESORS
Old 07-06-2010, 04:57 PM   #78 (permalink)
I upgraded my horn with the Fiamm High Blaster Low Tone and it does sound better than that Beep Beep horn but it isn't really any louder, actually probably a bit less loud. Not what I was hoping for. I May add a relay and the high tone horn as well perhaps that will make things a bit louder.
Old 07-11-2010, 01:59 PM   #79 (permalink)
Okay, I couldn't stand that Fiamm Highway Blaster. It is rated at 132db but it really doesn't sound like it is. I think some of those ratings are tested a certain way at a certain distance and aren't very accurate.
Anyway, I took off the Fiamm Highway Blaster and replaced it with the
WOLO Badboy. Hooked it up to the included Relay and installed an inline
20amp fuse between the battery and the relay. The relay mounted very easily on one of the battery hold down bracket posts. Ran the line from the original Honda horn switch to the Relay. Instead of cutting the wire I used
a homemade connector and plugged it into the Honda horn plug. Then ran 16gauge wire from the plug to the relay Number 85 position. Then ran a ground wire from the Number 86 position to where the battery ground is attached to the car body. I ran the inline fuse from the battery to the Relay number 30 position and then ran a 16 gauge wire from the Relay number 87 position to the positive terminal on the Wolo Badboy horn. Then one more ground wire from the Negative terminal to the frame of the car. There is already a ground connection close to the horn and it was really easy to hook up.
The way I ran the wires you can hardly see them and I covered most of the two wires going back to the horn from the Relay with some plastic wire cover I had laying around. Looks almost factory. And WOW, what a difference this
horn makes. I was pleasantly surprised with the sound quality and loudness.
No, it's not a 3000 Dollar Super Duper Train Horn but it does the job and it is much louder than the so called 132db Fiamm Highway Blaster.
I had mixed feelings on getting the Wolo thinking that the compressor would need to spool up and there would be a delay in sounding off. Not the case at all. The Horn sounds off immediately and loudly at the slightest touch of the stock horn button. You can give it short bursts or a very loud and attention getting long one. It will definitley get you noticed and in my opinion it was well worth the 39 bucks I paid at Autozone and the 30 minutes it took me to install it.
And if you don't want to mess with the relay you really don't have to.
I tried it without the relay first and it worked fine just hooking it up to the positive stock horn wire and running another wire to the ground. However,
I just felt better with the relay since the stock horn circuit is only 10 amps and they recommend a 20amp fuse. Didn't want to replace horn fuses on a regular basis or fry the stock wiring which I think is only a 20 gauge wire.
Anyway, I am very happy with the Wolo Badboy horn. Now I don't have to be embarrased to use my horn in case I need to.
Tags
hazard, horn, recall, safety
