How to adjust the head lights? - Insight Central: Honda Insight Forum
Old 09-01-2010, 04:21 PM   #1 (permalink)
Default How to adjust the head lights?
My headlights seem a bit too low. One side is lower than the other, but both are low.
I'm looking for info on how to raise them up a bit.
Is that info in the manual? I didn't seem to find it. What page?
MPBK is offline   Reply With Quote
Old 09-01-2010, 05:38 PM   #2 (permalink)
Νοthing on the Greek version of the manual also...
Yet, on each headlight body you will notice two small holes with arrows "printed" on them. Using a long straight-nose screwdriver you can adjust them lights horizontally and vertically from these two holes.
Old 09-02-2010, 05:28 PM   #3 (permalink)
Do a forum search - there's directions with a pictorial.
jonniedee is offline   Reply With Quote
Old 09-04-2010, 01:01 AM   #4 (permalink)
i wanna fix my headlights too
i was thinkin maybe the dealer can do it?
Old 09-18-2010, 08:43 AM   #5 (permalink)
Hi guys
1st post. Love the car (2009 Insight) to bits.I also think the low beam is a little low and also feel the lights could be more efficient. The bulb types chosen ( HB3 and H11) are not common in the UK and Phillips don't do many upgrades yet. I cannot find the 2 holes mentioned. Am I being dim?
Kurleyuk is offline   Reply With Quote
Old 09-18-2010, 09:01 AM   #6 (permalink)
I don't know about the holes and arrows thing.
You can either look on the Modifications and Technical forum for a post titled HUGE difference with slight adjustment to headlights or you can get an 8mm nut driver and look on the back side of the assembly for a silver colored adjustment bolt.
I did both. LOL
Old 10-28-2010, 01:07 PM   #7 (permalink)
Default Insight 2 lights
Looked on the tech bit and found all the info needed on adjusting the headlights. Its really easy and the difference is vast!! I would still like to fit the samebulbs as I did to my Renault Megane. Come on Philips Lighting get cracking!!!!!
Kurleyuk
