At least the first gen Civic Hybrid, it just has the basic VTEC system and it's only used to close the valves when coasting. It just doesn't pull that hard, even at 4k rpms... I can feel a huge difference in VTEC mode in the I1, but sadly, nothing on the HCH1.
No cylinder deactivation while fuel is being burned either.
From Wikipedia:
1.3-litre single overhead cam i-DSI lean-burn internal-combustion engine with VTEC Cylinder Cut-off System, which allows three cylinders to deactivate during deceleration. The engine generates 85 hp (63 kW) at 5,700 rpm and 87 ft·lb (118 N·m) of torque at 3300 rpm.
And:
The VTEC cylinder idling system of the engine closes the valves in three of the four cylinders when the car is decelerating, reduces the power lost to the engine by 50 percent and allows the IMA to extract more electrical energy during braking. The rocker arms operating the intake and exhaust valves have two modes: valve-lift mode or idle mode. They are engaged via a synchronizing piston. During deceleration, the synchro piston disengages the lift-mode rocker arm so that the valves remain at rest, effectively sealing off the cylinder.
Sam
