Fuel Filter? - Insight Central: Honda Insight Forum
Wheel & Tire Center
Old 01-28-2011, 04:52 PM   #1 (permalink)
Default Fuel Filter?
Where is it located and what is the mileage recommendation to replace it?
ricebow34 is offline   Reply With Quote Quick reply to this message
Old 01-28-2011, 07:20 PM   #2 (permalink)
It's on the tank unit along with the pump and sending unit. It should be replaced when a test of the fuel system shows the fuel pressure has dropped below acceptable levels. I would have to dig into the manual to find the exact test and tolerance levels.
Jayemtee is offline   Reply With Quote Quick reply to this message
Old 01-28-2011, 10:09 PM   #3 (permalink)
Here is a link showing how to get to the pump/transmitter inside the fuel tank.
DIY: How to change fuel pump / Fuel Guage Sender
Old 01-29-2011, 12:22 AM   #4 (permalink)
Found this in the manual:
FUEL FILTER REPLACEMENT
The fuel filter should be replaced whenever the fuel pressure drops below the
specified value (270-320 kPa, 2.8-3.3 kgf/cm2 , 40-47 psi with the fuel pressure regulator vacuum hose disconnected and pinched) after making sure that the fuel pump and the fuel pressure regulator are OK.
Old 01-29-2011, 01:18 AM   #5 (permalink)
The DIY info was for a first generation Honda Insight, I'm not sure about the other note. I strongly suspect the 2010 and 2011 Insights would be sorta along the same lines.
Old 01-29-2011, 10:02 AM   #6 (permalink)
Sorry, I got to this thread through Active Topics and it didn't indicate G1 or G2, yes the info I posted was for Gen 1. Good luck with getting the info you need for Gen2.
Old 04-22-2012, 12:29 AM   #7 (permalink)
Ehetleos's Avatar
Sorry to be raising this back from the dead but... any info yet?
The gas around here is basically crap and i cannot find anything useful in my manual so any info would help. If i wait to change the filtrre at the mileage stated on the manual it would be blocked, no dispute on that!
So what needs to be stripped from the car in order to reach the tank and how do we test the efficiency of the filtre prior to changing it?
Ehetleos is offline   Reply With Quote Quick reply to this message
Old 04-22-2012, 09:40 PM   #8 (permalink)
To test it you measure the fuel psi. Typically when you have low fuel psi its a blocked filter. Next is the regulator. If you have no fuel psi its typically the pump, although Ive seen bad pumps give low psi.
Ok, so remove your back seat, remove the rubber round plug, unscrew the outer plastic ring, pull out this cylinder of fuel delivery engineering. The filter is at the very bottom of the stack. Yeah, the filter is inside the gas tank mounted tothe fuel pump. This is why I advocate keeping half a tank as the fuel helps to cool your pump and this allows crap to settle to the bottom of your tank vs you sucking it all in.
Old 04-23-2012, 06:55 AM   #9 (permalink)
Ehetleos's Avatar
Thanks Cobb. But how do you measure thw fuel psi? Lost you there...
Old 04-23-2012, 12:11 PM   #10 (permalink)
Willie Williford's Avatar
Fuel pressure is normally measured at the "bleed valve"or schrader valve on the fuel lines. It should have an accurate gauge installed there for a precise measurement.
The measurement should be taken with the engine at idle for the min. reading.and then disconnect the vaucmn line that is hooked to the regulator and pinch it off to stop any air leak. That will show you the max. pressure. The engine will probably run rough for a few seconds due to the rich mixture. Any good mechanical shop should be able to help you.
Use: 389,000 mi. @ 58.2 LMPG.
Random Question
