Yup. I just leave it off or turn it off when approaching a series of stops and open the windows.
FYI, if you need ac, the best and most efficient is to set the ac on, temp to lo and regulate the temp inside the car using the blower speed.
If you use the auto feature it mixes heat with the air and uses the ac to remove humidity from the air.
