Basically it will tell you on its screen. It uses codes you can check in the manual or your local dealer.
For the most part you just need to rotate tires every 5 thousand, change oil every year or 10 thousand, and cvt fluid every 12. The rest is like 5 year or 100,000 miles.
Of course you want to check your air and cabin filter every 15 thousand.
