Stereo/Audio - Insight Central: Honda Insight Forum
Old 06-22-2011, 12:05 PM   #1 (permalink)
Default Stereo/Audio
I need help on the following subject:
How to enter the code to activate Audio system?
(Based on manual book you have to use reset button to enter but I could not find where is this button located?) My insight equipped with standard Audio system (no Dispay/GPS).
Thank you.
HHphan
hhphan is offline   Reply With Quote
Old 06-22-2011, 09:45 PM   #2 (permalink)
Originally Posted by hhphan View Post
(...Based on manual book you have to use reset button to enter but I could not find where is this button located?) My insight equipped with standard Audio system (no Dispay/GPS)...
I do not think you have to push a "reset" button. I believe you just punch the numbered pre-set buttons. Here is an excerpt from my 2011 Insight manual:
"If your vehicle’s battery is disconnected or goes dead, the audio system will disable itself. If this happens, you will see ‘‘ENTER CODE’’ in the frequency display the next time you turn on the system. Use the preset buttons to enter the code. On vehicles with navigation system, touch the icon to enter the code number, then touch the Done icon to set the code. The code is on the radio code card included in your owner’s manual kit. When it is entered correctly, the radio will start playing."
boB
2011 Insight EX
Taffeta White/Gray
Enigmatique is offline   Reply With Quote
Old 06-22-2011, 11:59 PM   #3 (permalink)
Welcome aboard.
You should see a card in the wallet in the glove box with a 4-6 digit code. Its like a busines card. You just push the buttons on the radio to unlock it.
If it is not there, call your dealer.
